General timing question
Old Dec 23, 2003 | 02:05 PM
GQ Cowboy's Avatar
Default General timing question
I have been having trouble with the timing on my car. I have adjusted the timing to the point it can no longer advance because the bolts will not allow the distributor to move any further.
The question is this... I can't get the red-mark to align with the grove for a stock setting. Has anyone else had this problem? If so, how did you correct this?
My car is sluggish when the gas is all-the-way down. I can't figure out how to adjust the timing to move it closer to the red mark. Currently I'm in between the red and the white mark. I have tried the ECU jumping but I still can't move the distributor enough forward to get to the 16 degree mark.
Old Dec 23, 2003 | 02:43 PM
mattssi's Avatar
Have you recently replaced your timing belt? Or your belt could have slipped a tooth!
Old Dec 23, 2003 | 03:47 PM
GQ Cowboy's Avatar
Default Re: (mattssi)
do you think the belt pulley tensioner is the problem?
I have not recently replaced my timing belt. I will check my records tonight and look over the belts tomorrow to confirm when the timing belt was changed.
BeatDX
Oct 16, 2013 04:59 AM
B18CYAAA
Apr 8, 2010 02:34 PM
Teamdiesel
Aug 11, 2008 06:03 PM
ALLMOTOR18
Sep 7, 2002 07:13 PM
