Coolant drain plug on SH Head Location??
I see on my Helms where the drain bolt is for the base prelude head, but it doesnt say anything of the location for the SH head. Are both bolts in the same area for both the base and SH heads? Or does the sh have it in a different location or doesnt have one at all?
I need to drain the coolant out of the head before i change the water pump.
The only one that I know of is the bleeder valve on the thermostat housing.
If you drain the radiator it all should drain.
