Ghetto vtec activation..lol
Old Dec 23, 2003 | 10:42 AM
phatrick2332's Avatar
Default Ghetto vtec activation..lol
I just did a compression check and im 175 across all 4, on a seriously beat on 180k b1. So im gonna put my z6 head i have laying around on and beat the **** out of it some more lol
I wanna kno how to do the toggle switch vtec activation. Just one wire off the black plug to one side and then the other side of the switch to a positive power source?
Old Dec 23, 2003 | 10:46 AM
PaImportTuner's Avatar
Default Re: Ghetto vtec activation..lol (phatrick2332)
what part of PA your in?
Old Dec 23, 2003 | 10:51 AM
just north of the burgh, nowhere near allentown lol
Old Dec 23, 2003 | 11:42 AM
blackZC (W)
Guest
Posts: n/a
Default Re: (phatrick2332)
yeh you know how old cars had the high beam switches on the floor, id get one of those and when you need vtec stop your foot at lets the *** whooping begin.
Old Dec 23, 2003 | 12:13 PM
thats a good idea, but i need someone to tell me exactly how to wire it.
Old Dec 23, 2003 | 12:18 PM
Jet Black's Avatar
Default Re: (blackZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackZC &raquo;</TD></TR><TR><TD CLASS="quote">yeh you know how old cars had the high beam switches on the floor, id get one of those and when you need vtec stop your foot at lets the *** whooping begin. </TD></TR></TABLE>
Not a bad idea....but add this and it would be sweet:
Setup the engagement with a relay, so when you tap the swtich vtec engages.
Then use the clutch switch to disengage the relay when you shift gears
Old Dec 23, 2003 | 12:25 PM
wiring wiring wiring wiring
Old Dec 23, 2003 | 09:35 PM
SiR Kid's Avatar
New User
Make it like a Nawwwwwws button, man! Have a button you hold in your hand so you can scream "VTEC just kicked in, Yooooooooo!!!!!" when you push the button!
Fucktard ricers.
Old Dec 23, 2003 | 09:39 PM
Default Re: (SiR Kid)
Are you refering to me?
Old Dec 23, 2003 | 09:46 PM
SiR Kid's Avatar
New User
Well, yes, It was, kind of. Why not just spend $20 and get a real RPM activated switch?
Sarcasm pwnz joo.
Old Dec 23, 2003 | 09:51 PM
well, Ive got a standard hatch with a stock motor and mpfi swap. In a month its history, In comes another sohc, 12.6:1 compression, fully built head, and quad carbs..u kno ricer style ****. My valve seals are shot on the b1 head so i just want to throw the z6 on for a temporary fix. I dont care what it is, as long as it will work for a month, probably less.
fucktard ricers
Old Dec 23, 2003 | 09:54 PM
SiR Kid's Avatar
New User
Just drive it without VTEC. It only effects 5000+ rpm levels, and MAYBE adds 10 hp at redline at the most.
I'll bet 90% of the time, you'd leave vtec off completely, or since it's a SOHC VTEC, just wire it to always be on. If you're not worried about the head, what's the low oil pressure hurting?
Old Dec 23, 2003 | 09:56 PM
10 hp on in a std hatch is a big gain over stock
waterfordtuners
22
May 27, 2010 06:07 AM
x4thGenCafe
25
Jan 5, 2008 09:00 PM
da6jdmteg
Jan 18, 2006 08:25 AM
DsBananas94LS
Dec 5, 2004 07:51 PM
