vtec hate mode
Old Jan 14, 2006 | 02:27 PM
da6jdmteg's Avatar
Default vtec hate mode
vtec does not kick in on its own. have to use toggle switch. any ideas to help me out and get it runnin right.
Modified by da6jdmteg at 3:47 PM 1/14/2006
Old Jan 14, 2006 | 06:52 PM
GoCarInteg's Avatar
Default Re: vtec hate mode (da6jdmteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da6jdmteg &raquo;</TD></TR><TR><TD CLASS="quote">vtec does not kick in on its own. have to use toggle switch. any ideas to help me out and get it runnin right.
Modified by da6jdmteg at 3:47 PM 1/14/2006</TD></TR></TABLE>
why would you need a toggle switch to control your vtec?
Old Jan 14, 2006 | 06:55 PM
Rajin's Avatar
Default Re: vtec hate mode (GoCarInteg)
Toggle switch. VTEC.
Moron.
I think we have our answer.
Why do you need a toggler for VTEC?
Old Jan 14, 2006 | 07:45 PM
GoCarInteg's Avatar
Default Re: vtec hate mode (Rajin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">Toggle switch. VTEC.
Moron.
are you talking about me?!?
Old Jan 14, 2006 | 07:48 PM
maldondo's Avatar
get the right comp and make sure your rev is set on the ecu also check all your wires r the vtec like presher swich and switch o2 sensor ect and also check your oil presure
Old Jan 14, 2006 | 08:11 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about me?!?</TD></TR></TABLE>
lmao, i'm pretty sure he was.
you probably just need the right ecu?
Old Jan 14, 2006 | 08:15 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: vtec hate mode (FlatBlackTeg)
lol sounds like the "slower switch" on that one video of the ef on street fire.
Old Jan 15, 2006 | 01:58 PM
da6jdmteg's Avatar
Default Re: vtec hate mode (stocker2shocker91)
its on the switch cuz i dont kick in. on the switch it does. but to be a smart a$$ like some its my ghetto vtec controller. i sell it for 50cent.
Old Jan 15, 2006 | 02:01 PM
da6jdmteg's Avatar
it would be nice if people tried to help other people instead of tryin to put others down when something messes up.
Old Jan 15, 2006 | 10:31 PM
RSD's Avatar
RSD
yeah, the guys asks how to wire a switch for vtec and u guys try to ravage his *******.
what if u hooked up a switch to the wire that people use to make vtec indicator lights?
Old Jan 17, 2006 | 10:56 AM
Hype-R Stalker
Default Re: (RSD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSD &raquo;</TD></TR><TR><TD CLASS="quote">yeah, the guys asks how to wire a switch for vtec and u guys try to ravage his *******.
what if u hooked up a switch to the wire that people use to make vtec indicator lights?</TD></TR></TABLE>
what the expletive are you talking about??
he didn't ask how to wire a switch, but to Fix the problem,
as to not needing the switch.
& to the OP, like I said, Do you have Right ecu or not?
Old Jan 17, 2006 | 11:16 AM
Danziver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da6jdmteg &raquo;</TD></TR><TR><TD CLASS="quote">it would be nice if people tried to help other people instead of tryin to put others down when something messes up.</TD></TR></TABLE>
Welcome to H-T.
Old Jan 17, 2006 | 11:44 AM
Rajin's Avatar
Default Re: vtec hate mode (Danziver)
I'm thinking he fails to have the right ECU for his applications.
Otherwise, he doesn't know whats going on, and hasn't througly checked out his car to find the multitude of possible problems.
Old Jan 17, 2006 | 05:30 PM
RSD's Avatar
RSD
Default Re: (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">
& to the OP, like I said, Do you have Right ecu or not?</TD></TR></TABLE>
aparently u didn't read hte original post before it was edited
Old Jan 18, 2006 | 02:54 AM
Hype-R Stalker
Default Re: (RSD)
Maybe you should of posted before he edited it then?
&my first post was when he "edited" it so yeah, my bad for not being here asap.
Old Jan 18, 2006 | 02:55 AM
Stoic's Avatar
change your VTEC fluid and it'll fix the problem
Old Jan 18, 2006 | 06:37 AM
Rajin's Avatar
Default Re: (Stoic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoic &raquo;</TD></TR><TR><TD CLASS="quote">change your VTEC fluid and it'll fix the problem</TD></TR></TABLE>
Sure it isn't the VTEC Diversifier. Them go out alot.
Old Jan 18, 2006 | 06:48 AM
DA6mike's Avatar
Default Re: (Rajin)
sound like ecu,friend of mine had a same problem when he swaped H22 in to accord and blowned ecu afteword,so he got a difrent ecu none vtec so he putit on switch
Old Jan 18, 2006 | 06:51 AM
DA6mike's Avatar
Default Re: (DA6mike)
Rajin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA6mike &raquo;</TD></TR><TR><TD CLASS="quote">sound like ecu,friend of mine had a same problem when he swaped H22 in to accord and blowned ecu afteword,so he got a difrent ecu none vtec so he putit on switch</TD></TR></TABLE>
You didn't make the least bit of sense.
Old Jan 18, 2006 | 06:55 AM
DA6mike's Avatar
Default Re: (Rajin)
I'm seying that he has prod. none vtec ecu
Old Jan 18, 2006 | 08:25 AM
GSRintegra_Bob's Avatar
Did you check your vtec fluid????? its one part octane booster, one part purifed water and one part oem honda vtec mix....
IDIOT!
Shoot5Hole84
Apr 17, 2010 10:20 PM
sileighty_911
Sep 2, 2007 05:55 PM
Tatakai
14
Oct 7, 2005 07:03 PM
HatchBox
Mar 7, 2005 08:40 PM
DsBananas94LS
Dec 5, 2004 07:51 PM
