IT WONT FIT!!!!!!
Old Dec 23, 2003 | 08:25 AM
94turbolude's Avatar
Default IT WONT FIT!!!!!!
trying to put a b16 auto in a 98 civic ex and the damn thing is to wide WTF?!?!?! this is a stock motor in this car why wont it clear? do i need to use a mount kit ot what? I am totally lost, called hasport and they said that you MUST use there mounts BUT they wont be out till feburary
HELP
Old Dec 23, 2003 | 10:28 AM
Kamin's Avatar
Default Re: IT WONT FIT!!!!!! (94turbolude)
drop the motor at a steep angle
transmission side lower
Old Dec 23, 2003 | 10:47 AM
IS3Fifty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94turbolude &raquo;</TD></TR><TR><TD CLASS="quote">trying to put a b16 auto in a 98 civic ex and the damn thing is to wide WTF?!?!?! this is a stock motor in this car why wont it clear? do i need to use a mount kit ot what? I am totally lost, called hasport and they said that you MUST use there mounts BUT they wont be out till feburary
HELP</TD></TR></TABLE>
bullshit, you dont have to use their mounts. Stock mounts will work fine, you will need a B series tranny mount.
Old Dec 23, 2003 | 11:49 AM
EP3_05's Avatar
It should fit since that chassis came with a b16a2 in 99. I am wondering if the automati transmission has a different mount. You should be able to use stock mounts. My best guess is that you will need to get a b series automatic trans mount.
Old Dec 23, 2003 | 11:55 AM
Civic Rs's Avatar
New User
Default Re: IT WONT FIT!!!!!! (91civic)
One of my friend put manuel tranny in a 96 teg and he need to remove the passenger mount to put the manuel one because that was not the same. So I presume you have the same situation but in reverse ????
Old Dec 24, 2003 | 08:17 AM
so your tellin me that if i get a b series auto trans mount that i can use the stock d series drive mount and what do i do for a rear mount? stocl b series engine and d series chassis mount?
thanks
Old Dec 24, 2003 | 08:27 AM
VTECVillain's Avatar
Default Re: (94turbolude)
The 96-00 Civic B and D series use the same upper tranny mount, this is for manuals, not sure about autos. Say you have a manual 98 EX and put in a B16 with manual tranny, you can simply reuse the stock EX upper tranny mount. You should be able to do this with OEM mounts in the same manner - try using the EX auto tranny mount. If that doesn't work you might need a 97-00 CRV auto B series tranny mount and rear mount. I'm throwing out some possibilities here since I have not done this swap before, just trying to think logically how it should work.
Do you even have the motor/tranny sitting in the engine bay about where it should be yet? Hopefully you've changed the B16 driver's side bracket and mount to a 99-00 Civic Si bracket and mount, that's a must. This will line up the motor and allow you to try different configurations for the tranny.
ALL IMPORT
Jul 11, 2010 04:16 AM
turbob16ef
10
Dec 31, 2005 07:41 PM
turbob16ef
Oct 1, 2005 07:19 AM
sohcvtec1995
Sep 22, 2003 10:44 PM
Woody_geeser
Sep 11, 2003 07:56 PM
