flywheel dust cover install?
Old Dec 23, 2003 | 07:51 AM
92civeg's Avatar
Default flywheel dust cover install?
i bought a flywheel dust cover for my b16a. The cover i got is from a b16a2. Im assuming it will fit but i got under my car yesterday and it looks like u have to take off the oil pan to get it to fit on, is this true? Can anyone shed some light on how to install it, i didn't expect it to be complicated at all
Old Dec 23, 2003 | 08:05 AM
Flamenco-T's Avatar
Default Re: flywheel dust cover install? (92civeg)
you don't have to take the oil pan, it's just a few 4-5 bolts.
stan
Old Dec 23, 2003 | 12:36 PM
BeerMan's Avatar
Default Re: flywheel dust cover install? (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">you don't have to take the oil pan, it's just a few 4-5 bolts.
stan</TD></TR></TABLE>
yeah, it uses the same studs, or bolts, that hold the oil pan on, but you don't have to remove the oil pan.
Old Dec 24, 2003 | 02:14 PM
92civeg's Avatar
Default Re: flywheel dust cover install? (BeerMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerMan &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, it uses the same studs, or bolts, that hold the oil pan on, but you don't have to remove the oil pan.</TD></TR></TABLE>
so i have to remove a few bolts from the oil pan and slide it into place?...anyone have pics of one installed?
Old Dec 24, 2003 | 02:27 PM
BeerMan's Avatar
the little tabs on the ends of the cover have holes in them. locate the appropriate bolts (the ones that match up to those holes) on the oil pan. take out those bolts. hold the dust cover flush to the tranny and oil pan. replace said bolts. you will understand if you look under the car.
no pics, you shouldn't need a picture.
Old Dec 24, 2003 | 02:31 PM
92civeg's Avatar
i would think if i put it inbetween the oil pan and the block i would mess up the gasket at have a leak?
Old Dec 31, 2003 | 02:48 PM
92civeg's Avatar
i figured out how to put it on now...but i have to unbolt my "rear engine stiffener"..i started to today and some oil started to seep out so i quickly put the bolt in.......so do i have to drain the oil before i take this off?
Old Jan 1, 2004 | 09:54 AM
BeerMan's Avatar
You shouldn't have to drain the oil. But, might as well change the oil while you're under there.
Old Jan 1, 2004 | 11:31 AM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerMan &raquo;</TD></TR><TR><TD CLASS="quote">You shouldn't have to drain the oil. But, might as well change the oil while you're under there. </TD></TR></TABLE>
always a good idea... i dont think oil sits in the pan that high where the cover is? but i guess couldnt hurt changing the oil while your getting dirty...
Old Jan 2, 2004 | 09:28 PM
92civeg's Avatar
Default Re: flywheel dust cover install? (dunkd)
For an hour today i tried to put that thing on it was a major pain , and it wouldn't fit. Im just going to leave it off. Its been off for a year and hasn't affected anything yet.
I cant put it on without taking off the rear engine stiffener, and i cant take off the rear engine stiffener without taking off the header
Old Jan 3, 2004 | 06:43 PM
dunkd's Avatar
header isnt hard to get off at all, its worth it.. i woulda drive my car without that shield for too long
Old Jan 3, 2004 | 08:29 PM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">header isnt hard to get off at all, its worth it.. i woulda drive my car without that shield for too long</TD></TR></TABLE>
Y not i have been doing it for 2 1/2 years now no probs. Also i am always working on it and something as trivial as that just gets on my nerves like my T belt covers i just threw them away.
Old Jan 3, 2004 | 11:48 PM
IN VTEC's Avatar
I've done it before when doing clutch jobs. It takes a little bit of wiggling to get it up in there.
You take off like 5 bolts (2-17mm and 4-12mm I think), remove the front stiffener, wiggle it in and put it back together again.
Old Jan 4, 2004 | 01:07 AM
Devlins 91LS's Avatar
Default Re: flywheel dust cover install? (IN VTEC)
yeah, take out both stiffeners, slide the bish in there and bolt it up.
I put mine back on after changing my clutch in like 5 mins.
Old Jan 4, 2004 | 09:39 AM
92civeg's Avatar
Default Re: flywheel dust cover install? (Devlins 91LS)
it would be easy if i could get my stiffeners off without taking the header off, i loosened both bolts on my rear stiffener and one dropped right onto my header and is too long to get out( sorry if this is hard to understand). I really would like to get it on though
Old Jan 5, 2004 | 08:22 AM
So unbolt your header just enough for you to get the bolts out &lt;shrug&gt;
You don't need to take the whole thing OUT, if you just unbolt it from the head and from the rest of the exhaust you should be able to move it enough to get the space needed.
Old Jan 5, 2004 | 11:23 AM
92civeg's Avatar
are all b series dust covers the same?
Old Jan 5, 2004 | 06:26 PM
92civeg's Avatar
Old Jan 7, 2004 | 12:35 PM
I assume so, all b series transmissions are interchangeable, so wouldn't their periferals? (sp)
lazyxmofo
Mar 9, 2011 06:26 PM
JasonST
Oct 2, 2008 11:17 AM
shbrown
Jan 28, 2006 03:46 PM
AF-b16a1
Aug 2, 2004 09:53 PM
Horatio
10
May 3, 2004 01:44 PM
