jdm final drive
Old Dec 22, 2003 | 09:08 PM
Shabir's Avatar
Default jdm final drive
jdm final drive - what would be the top speed using the 4.7 gear set in kmph?
is it worth to swap from 4.4 to 4.7???
thanx
Old Dec 23, 2003 | 07:33 PM
ljoe's Avatar
Default Re: jdm final drive (Shabir)
yes, because then you sell me the 4.4 ring gear
Old Dec 23, 2003 | 11:26 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shabir &raquo;</TD></TR><TR><TD CLASS="quote">jdm final drive - what would be the top speed using the 4.7 gear set in kmph?
thanx</TD></TR></TABLE>
err..i have a 4.7fd in my tranny, but I haven't tried to top out my speed.
At 80mph my rpm's are at 4400/4500rpm; im using a GSR 5th gear too.
but technically, if you raise your final drive ratio it will hamper your top speeds but increase your acceleration. The acceleration is what I like about the 4.7....get up and go go go gearing. Also wheel size/diameter should taken into account when shortening your gear ratio. A 16" wheel + 4.7 final drive in more ways than others, go hand in hand, as seen with the JDM 98+ ITR. But, using a 15" + 4.7fd doesn't hurt, but technically it does - it will hurt your top end speeds if you race against a ghost of your car on 16"+ 4.7. The 16" would win.
5zigen_dc5
Mar 31, 2006 05:06 PM
Kengs
Aug 13, 2004 08:49 PM
slofu
Sep 4, 2002 02:05 PM
Apex i ITR
Jan 16, 2002 03:35 PM
