lma's...symptoms of them going bad?
Old Dec 22, 2003 | 08:43 PM
RacerXI's Avatar
Default lma's...symptoms of them going bad?
My motor has a fairly loud tick at idle. it seems to go away over about 5K or so, but it is very apparent once the motor gears down. Any ideas. A little background on the setup. I was told by a mechanic that worked on it the wristpins in the motor were bent due to too much boost (10psi jrsc) and too much compression (10.5:1 w/ je slugs). thanks.
Old Dec 22, 2003 | 09:58 PM
CaptainMorgan's Avatar
Default Re: lma's...symptoms of them going bad? (RacerXI)
it could be your injectors. What you could do is find a way to disable each spark in each cyl, by pulling the spark plug wire. do it to each one of them at a time. If its your wrist pin the tick should go away on the the spark disableed one. this is how you find rod knock, i figure its the same way.
Project_EK
Jul 8, 2007 09:14 AM
AnthraxVX
Aug 9, 2006 03:08 PM
H22FAN
Mar 25, 2004 02:16 PM
magic hat #9
Aug 14, 2003 09:34 AM
B18EG6
Oct 28, 2002 12:17 PM
