steering wheel w/ airbag REMOVAL
Remove steering column cover or look for an access panel on the underside of the steering wheel. You're looking for a bright yellow wiring harness. Unplug and then !carefully! remove steering wheel from column. Take note of the angle of the stock wheel for installation of the new one.
wuts up man if u really wanna play it smart and safe disconnect the negative battery cable. ive taken off airbags on acura tls im sure its teh same concept on a del sol.look for a cover panel under neith the steering wheel the connector should be under there. the color of the connector is yellow and blk. on the sides of the steering wheel there should be lil covers. take those out in there you should see a screw on each side. im not sure if its a torx screw but u have to take those out inorder to get the air bag off. everything else is simple make sure wheel is straight and take the nut that holds the wheel on.
hopefully this might give u sum sort of direction to do it. good luck.
crazyhouse2011
21
Apr 25, 2013 05:58 PM
