I know its been asked but...
Old Dec 22, 2003 | 01:26 PM
SdGSR01's Avatar
Default I know its been asked but...
To fit a GREDDY kit onto my 01 GSR what do i need to do? I was planning on using Hondata instead of the blue box anyway, but I read something about needing a custom down pipe. Is it just a down pipe that I'd need or is there other plumbing issues that I may face? Also about the carb exemption, it should still pass off as legit because the carb sticker is on the plumbing somewhere isn't it? I know I'd be better off getting a Drag kit, but I gotta stay Carb legal. And the more JRSC dynos I see, the more a turbo appeals to me. Help a brother out you guys. I need boost in my life
Old Dec 22, 2003 | 01:33 PM
10seceg's Avatar
Default Re: I know its been asked but... (SdGSR01)
It really depends on what kind of power you are wanting. If you are wanting to stick w/ little boost the keep the blue box and buy a front mount for a little more power. If your stuck on hondata..buy the front mount..get some 550cc injectors and run 12 psi tuned. Im not sure if its carb legal b/c im in SC and cops just dont care about that crap...so i would just call hondata and ask them b/c honestly it just boils down to how much power you are wanting to run....safely !
Old Dec 22, 2003 | 01:47 PM
SdGSR01's Avatar
Default Re: I know its been asked but... (10seceg)
Thanks for the input. Love the screen name. Anyone know about the down pipe issue?
Old Dec 22, 2003 | 05:45 PM
10seceg's Avatar
i dont understand why you couldnt use the downpipe you bought w/ the kit?!?! unless you just want bigger(i.e. 3 inch) i mean..bigger helps it spool up and gives more power..but its up to you really! if you find out where you read that please let me know..ill like to see it!
Oh and thanx for the compliment! hope you get it running right!
Old Dec 23, 2003 | 02:36 PM
SdGSR01's Avatar
I thought the down pipe had to be custom because of the two sensors in the 01, as compared to the 99 which is what the kit is made for.
Old Dec 23, 2003 | 06:17 PM
10seceg's Avatar
the only different in the integras as far as downpipes goes is itr's! (at least thats what ive been told by my friend w/ an itr!) if you find out any different post it up!
Old Dec 23, 2003 | 06:23 PM
The Shodan's Avatar
Actually, you want a slight variation from the downpipe, instead of 3" straight out from the turbo, the increase in pipe diameter actually creates a "pull" of back pressure allowing the exhaust velocity to move a bit more quickly.. Lot of INDY race cars use this method for more power
Old Dec 24, 2003 | 10:28 AM
SdGSR01's Avatar
Default Re: (The Shodan)
Well I guess when I get the kit and get it all laid out, I'll see for sure
Old Dec 24, 2003 | 10:31 AM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SdGSR01 &raquo;</TD></TR><TR><TD CLASS="quote">I thought the down pipe had to be custom because of the two sensors in the 01, as compared to the 99 which is what the kit is made for.</TD></TR></TABLE>
There is one in the DP it self and then you have another O2 in your stock cat that is 2 not 1 you will be fine i had one on my Si but i went OBD1 and did away with teh other sensor, that and i didn't run anything but open DP
Old Dec 24, 2003 | 10:43 AM
SdGSR01's Avatar
Default Re: I know its been asked but... (99blackcivicSi)
Cool man, thanks for the input. Thank all you guys for the input actually.
Drkaccrd
Jun 10, 2005 09:45 PM
mugenhatch92
Apr 29, 2005 12:48 PM
Eyetattoo
Sep 27, 2003 09:44 AM
Boosted GSR
Apr 10, 2003 12:07 PM
The Destroyer
Jan 8, 2003 04:33 AM
