Turbomanifolds for ITR
Old Dec 22, 2003 | 01:18 AM
mh's Avatar
mh
Default Turbomanifolds for ITR
Does a manifold for a GSR or a B16 bolt on. or does it have to be a spec for ITR?
Old Dec 22, 2003 | 07:47 AM
Muckman's Avatar
Moderator in Chief
Default Re: Turbomanifolds for ITR (mh)
It needs an ITR head specific flange to bolt on.
Old Dec 22, 2003 | 08:14 AM
mh's Avatar
mh
Default Re: Turbomanifolds for ITR (Muckman)
ok, thanks.
Old Dec 22, 2003 | 09:38 AM
dmotoguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">It needs an ITR head specific flange to bolt on.</TD></TR></TABLE>
are you sure...
Old Dec 22, 2003 | 10:13 AM
boostedcvc's Avatar
Default Re: Turbomanifolds for ITR (dmotoguy)
for an exhaust manifold any b-series manifold will bolt on!
Old Dec 22, 2003 | 10:19 AM
Kwuaymaikrup's Avatar
I hope you are being sarcastic.
Old Dec 22, 2003 | 01:59 PM
mh's Avatar
mh
Default Re: Turbomanifolds for ITR (Kwuaymaikrup)
well i know for sure that the b20 exhaust manifold does not bolt on. fitted the old b20 gasket today. there is one hole that doesn't line up.
Old Dec 22, 2003 | 04:04 PM
Kendall's Avatar
Any manifold from a B series will fit, the one bolt from a B20 manifold won't make that big of a difference. Don't listen to the guy who said that the ITR has a specific flange needed for it, because the ITR head is just a mildly ported version of the B16 head.
Old Dec 23, 2003 | 01:24 AM
mh's Avatar
mh
Default Re: (dc231)
it isn't "bolt on" if you have to modify the manifold...... guess there is a diffrence none vtec vs. vtec heads then.
Old Dec 23, 2003 | 09:44 AM
dmotoguy's Avatar
Default Re: (mh)
it bolts on.
Old Dec 24, 2003 | 06:25 AM
Muckman's Avatar
Moderator in Chief
Default Re: (dmotoguy)
How can it bolt on? The ITR intake manifold will not bolt onto a GSR head without modification... ???
Old Dec 24, 2003 | 07:16 AM
500hpsi's Avatar
Default Re: (Muckman)
A b16 and b18c intake manifold don't fit because of the larger intake ports. But, the exhaust manifold will fit with out problems. However, the B20 and B18b does not cross over to the vtec heads - Only b20 and b18b intake and componets can fitted with each other.
The best to find out call the Acura dealer and ask the for the part number; and, then call the your local Honda dealer to see if the Acura part number exist and to what vechicle it applies too.
JDM_VTI_Hatch
Feb 4, 2010 04:15 AM
richboi
Mar 8, 2008 11:16 AM
92LsTegra
Oct 13, 2004 06:27 PM
wreckedmyteg
Aug 4, 2004 07:51 PM
SiR-Chris
Jan 24, 2004 11:41 PM
