Possible dead clutch in a 96 Accord?
My friends clutch doesnt work. I just wanna pass this by you guys to see if anyone has had this problem and also to confirm if the clutch is bad or not.
The symptoms are : clutch goes in but does not come back out.......when the clutch is in the car does not go into gear.
He has been driving via rev matching I just wanna see who else has had this problem, Im assuming his clutch went out. Can anyone please confirm this? Thx
if the pedal doesnt come back out, the master cylinder could be messed up. i would check that first before pulling the trans.
edit: or what dude above me said.
hydraulic problem, either slave cyl or master cyl or just bleed, i think i had the same problem once when i accidentally left the bleeder open a bit, just bleed that ****.
Xxcivic97xX
Jun 1, 2011 02:07 AM
xhatchracerx
Aug 31, 2007 01:22 PM
