idle timing setting
did you jump the service connector before setting it?if it still isn't in spec within the adjustment range,check the cam timing-it must be off.
chris
chris
well my ECU is throwing knock sensor code. so i was told that if the CEL is on.. the setting will be set to retard. true? because i advanced it all the way and its almost there to the orange line...
Chronicsinners
Feb 4, 2005 02:41 PM
non-VTEC
Jan 27, 2002 12:15 PM
