Do I need valve spring retainers?
Old Dec 21, 2003 | 02:59 PM
Grandprix's Avatar
Default Do I need valve spring retainers?
What is the purpose of titanium valve spring retainers? Cant I just use my stock ones with 105k miles? Can I use stock ones with CTR cams (with ITR springs)? Can I use stock ones with JUN 2 cams (with some beefy springs)?
Old Dec 21, 2003 | 06:25 PM
lilredhatch's Avatar
Default Re: Do I need valve spring retainers? (Grandprix)
i heard stock ones tend to break under high rpm applications....
Just what I have heard!
Old Dec 21, 2003 | 07:14 PM
Grandprix's Avatar
Default Re: Do I need valve spring retainers? (lilredhatch)
Im wondering if the retainers are needed because the springs are so much stronger, they can break the stock ones. As for the RPM, I plan on keeping the 8k redline.
Old Dec 21, 2003 | 08:00 PM
ARIZONA's Avatar
That is exactly why they are used. The titanium springs may be just a little too stiff for stock retainers... they may work, but surely not as reliable. I don't see any reason to upgrade retainers ONLY, I don't think that was what you were saying though either.
Old Dec 22, 2003 | 03:12 AM
quik sol's Avatar
itr cams you wont need to update your valve train, but if you use the jun cams you should use titanium retainers AND dual valve springs
Old Dec 22, 2003 | 05:46 AM
Lsos's Avatar
I thought it was purely for weight reasons....titanium is actually not stronger than steel.
Old Dec 22, 2003 | 08:21 AM
quik sol's Avatar
titanium or stainless steel upgrade the fricken valve train...
Old Dec 22, 2003 | 05:43 PM
Kendall's Avatar
Default Re: Do I need valve spring retainers? (Lsos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsos &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was purely for weight reasons....titanium is actually not stronger than steel.</TD></TR></TABLE>
If the weight is too great, then it creates unnecessary stress due to inertia. A lighter retainer having less mass creates less stress upon itself and the rest of the valvetrain and thus is more resistant to breakage.
qais_vtec
28
Jul 26, 2012 06:31 PM
Civic89stdB16
Dec 1, 2008 12:05 AM
rorik
28
Dec 25, 2007 12:44 PM
SPOONfdEK
Jan 11, 2004 07:20 PM
Black R
Jun 15, 2001 06:58 AM
