just finished my swap.....
Old Dec 21, 2003 | 01:50 PM
crxturboh22's Avatar
Default just finished my swap.....
sup yall I just finished my swap.. i blew my piston rings on my old motor.. (overboosting.) so I got another block and. finished it today. I added a Greddy Head gasket (2.0mm) yap hella thick.. anyhow the motor is running kind ruff.. its making some weird noise.. but its running fine... I've only been driving it for 15 min.. does it take time to quiet down....? i dunno from what i heard smoke is gonna be coming out (blue,white ) for about 30 min. or so.. cuz of the oil and water mixing... and the block had some rust on it (sleeves) cuz it was just seating there.... let me know wht you guys think..
Old Dec 21, 2003 | 05:22 PM
blah13's Avatar
Default Re: just finished my swap..... (crxturboh22)
What motor and setup? Why the thincker head gasket, lower comp? If so you might end up regretting that, esp with boost, thicker headgaskets tend to fail more easily. Either way good luck.
Old Dec 21, 2003 | 05:27 PM
Default Re: just finished my swap..... (blah13)
its a D16z6 swap.. and the thicker gasket is for LOWER COMPRESSION which is good.. you don't want no high compression for turbo... plus its by greddy.. so
h22nate
May 13, 2011 06:01 AM
cbrodac0424
Apr 30, 2005 04:43 PM
Type_gsR
Feb 3, 2004 04:43 PM
Hassan
May 4, 2003 08:48 PM
deacs
Oct 4, 2002 07:56 AM
