Ideas on thicker head gasket and block gaurd..
I tried to do a search but came up empty.
I think I blew the head gasket on my car. I am not sure that this is the only problem. It might be something even more I have not pulled the head as yet so not sure what it is. I am on vacation right now.
What are the opinions on using a thicker head gasket? Good idea or bad? Also if I want to install a block gaurd without taking the block out would that work? I have a JG block gaurd. Is it even worth it?
Let me know what some of you guys think about this..
Thanks
Thanks
Re: Ideas on thicker head gasket and block gaurd.. (Hassan)
inline pro makes lower compression headgaskets for b series motors and h series motors. they can handle 20+ lbs of boost and 400 hsp to a stock block. call them at 703-644-1788. they're in virginia.
Re: Ideas on thicker head gasket and block gaurd.. (TORQUE MONSTER)
Im pretty sure if you got a thicker head gasket, you need to get cam gears to advance the timing as well, I used to have a cometic for my prelude 8:1 compression, but now i got rebuilt motor with a cometic turbo head gasket. Do any of you guys know whether the timing should be advanced with this head gasket? The thickness is like three oem head gaskets connected together like a slinky? thanks
New User
Re: Ideas on thicker head gasket and block gaurd.. (turbobboy)
with the inline pro HG you do need cam gears but it works very well and I have there block gaurd and hg and with no tuning at all I put down 230whp and 192wtq this weekend at carlisle.....my motor stock is 10.6:1 and I am runnin 11psi on it with no problems at all
Re: Ideas on thicker head gasket and block gaurd.. (ITR41)
what fuel management do you have and what settings did you set the cam gears?
I have a cometic turbo gasket and im tryin to figure out what to set the cam gears at.
jdm knight
05-02-2010 03:40 PM
