HybridAutomotive.com reliable?
I want to buy their front/back 94-01 integra disk brakes but I want to know if they are reliable and if anyone here has dealt with them. Also, is this EVERYTHING I need to swap? I see it comes with the proportioning valve and brake booster and master cylinder, which is very nice.
Anyone recieved products from them? Thanks alot!
Also, once I get this swap what can I do to upgrade it?
SS brake lines?
new brake pads?
SS brake lines?
new brake pads?
I ordered the same thing from them about 8 months ago, expect to replace all the rotors and pads because mine were fucked when I recieved them. I also had a problem with one of the rear spindles being bent. Scince I did'nt install my 4 wheel discs immediatly I ran out of my 30 day warrenty before I even knew I had got bent ****. I made a post about it here https://honda-tech.com/zerothread?id=598178.
If I had to buy this from them again, I guess I would make sure I was ready to bolt the **** on the day I got it. Jeff seems like a reasonable guy and business man. Just make sure you know what you got before your 30days is up. Or you could end up spending alot more than you planed like I did.
-globl
[EDIT] If you want steel braided lines, theres no better time to throw them on than while you're doing this. I threw on some goodrich lines when I did my swap.
-globl
SiR Inspired ED7
Suspension & Brakes
Feb 24, 2010 03:31 PM
yeegsr
11
Sep 15, 2004 12:12 PM
