valve adj.?
Old Sep 23, 2001 | 12:46 AM
Cereal_Killer's Avatar
Default valve adj.?
need any tips on valve adjustment? on a ZC...
what are they supposed to be set at? i heard .006 on the intake and .007 on exhaust. do the cams need to be in any type of position in order to be set right?
Old Sep 23, 2001 | 12:57 AM
dustin's Avatar
Default Re: valve adj.? (91efzc)
Piston has to be at TDC for each cylinder to check the clearances, and the motor has to be entirely cold.
Dustin
Old Sep 23, 2001 | 01:11 AM
Default Re: valve adj.? (dustin)
which ones do i set? the ones directly close to the cylinder? areee those tolerances right?
one slow coupe
Dec 24, 2004 05:21 AM
OnDaBottle
Oct 20, 2004 12:10 PM
Ri5e
Aug 9, 2002 07:48 AM
SpoonFed
May 9, 2002 08:09 PM
