STAGE 2 OR STAGE 3 CAMS
Old Dec 19, 2003 | 06:59 PM
TeamMGIperformance's Avatar
Default STAGE 2 OR STAGE 3 CAMS
I have a B18B1 in a 1993 Honda Civic Dx I drive my car to work everyday but I also I like to go you the track and run. What stage cams should I do. And by the way I will do head work and I have the money to do other upgrade alos.
Old Dec 19, 2003 | 07:31 PM
miller's Avatar
Default Re: STAGE 2 OR STAGE 3 CAMS (TeamMGIperformance)
cams are designed to run with different types of setups, more details on the motor will be helpful...compression etc...Miller
Old Dec 19, 2003 | 09:26 PM
1hotintegra's Avatar
Default Re: STAGE 2 OR STAGE 3 CAMS (miller)
yea more info
Old Dec 19, 2003 | 09:57 PM
NitrousB.I.G.'s Avatar
Default Re: STAGE 2 OR STAGE 3 CAMS (1hotintegra)
You should call the cam manufacturer and talk to the tech guys they can tell you what cam would work the best with the setup that you are planning. They know what the cam was designed for and can give you ideas that will give you the most efficient set up.
85_305
Honda Civic (2001 - 2005)
18
Jul 31, 2009 04:54 PM
RIJMNT
Apr 13, 2005 03:12 PM
deez nuts
Sep 9, 2004 10:09 PM
justmotor13
Mar 17, 2003 05:26 PM
