Troubleshoot: Transmission making noises (humming & whining)
Old Dec 19, 2003 | 12:14 PM
vteec's Avatar
Default JDM 98 Spec Tranny Noises.
Hi,
My 98 Spec JDM ITR tranny is making a humming noise ('moaning') all the time.
This has been so from when it has been imported from japan, it has around 125k on the odo.
Here in Malta we cannot go and buy the parts over the counter, there is only one dealer and it takes 3-4 weeks for the pre ordered parts to arrive.
I am suspecting the input shaft bearing and i was going to order that part before opening up the tranny ....but i have searched and it seems it could be:
Countershaft missing teeth,
LSD Bearings,
etc............
I know one could order every bearing and do a complete rebuild but i am on a budget right now and would like to repair the tranny now and forget that humming noise cause its driving me crazy !!
Can someone please try to help me to identify what needs to be replaced by my description of what's happening?
Basically my tranny whines and hums all the time and the noise increases when i am in higher rpms.
Help me please guys !
rgds,
Old Dec 19, 2003 | 12:27 PM
RockstarJR's Avatar
Default Re: JDM 98 Spec Tranny Noises. (vteec)
Wish I could help... Nobody near you that could take a look?
Old Dec 19, 2003 | 12:32 PM
vteec's Avatar
Default Re: JDM 98 Spec Tranny Noises. (ITRChris)
Thanks for the quick reply itrchris .....
the problem is that i don't want to order the input shaft bearing and open up the tranny to find for eg. the lsd bearing which are shot....that would mean 3-4 weeks with no car and the tranny opened up awaiting for the parts to arrive.
anyone else please?
Old Dec 19, 2003 | 12:50 PM
typer_801's Avatar
There have been several posts on Input shaft bearings. Do a search, that's how I determined mine failed. Here's how to identify a failing input shaft bearing:
Car stopped, engine on, transmission in neutral, clutch not depressed and you get the moaning sound, you've likely got a defective input shaft bearing. Same conditions with clutch depressed, you've got a failing throw-out bearing.
LSD would only make noise when the wheels are turning, so you shouldn't have any noise until your moving.
Old Dec 19, 2003 | 01:00 PM
vteec's Avatar
Default Re: JDM 98 Spec Tranny Noises. (typer_801)
typer_801 : i have just fitted a new ACT clutch with a new thrust so i can rule the clutch related problem out......
i will try the other thing you are telling me ..............
anyone else please?
Old Dec 19, 2003 | 01:10 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteec &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
does the moaning go away with the clutch pedal pressed down?
Old Dec 19, 2003 | 09:14 PM
vteec's Avatar
Default Re: JDM 98 Spec Tranny Noises. (Dan GSR)
Yes it does.............
bet the best thing to do is to order the input shaft bearing, and hope that the humming will go away by replacing it...............
hoping i won't find nightmares when we open it up.........
Old Dec 20, 2003 | 08:00 AM
b19coupe's Avatar
Order the input shaft seal at the same time.
Old Dec 20, 2003 | 08:44 AM
Bbasso's Avatar
If you open it up and you see that your going to need more parts then you thought, You can allways call Len have have him overnight a few parts to get you back on the road.
As for the inputshaft bearing do a search under my name I had a big mess.
Old Dec 20, 2003 | 10:07 AM
D's Avatar
D
Default Re: (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote"> You can allways call Len have have him overnight a few parts to get you back on the road.
len overnights to Malta? damn.
Old Dec 20, 2003 | 10:45 AM
vteec's Avatar
Default Re: (D)
Thanks a lot for the help guys !
bbasso : i did a search under your name and now i am really worrying !!
i will let you know how it goes ...........
rgds,
Old Dec 20, 2003 | 05:47 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteec &raquo;</TD></TR><TR><TD CLASS="quote">Yes it does.............
I already know what the problem is
its the input shaft bearing...but change both bearings
the clutch housing side is probably shot
so now the one on the gear housing side is taking more load.. is probably out of spec
change both bearings on the input shaft
I did this to mine...works great
Old Dec 20, 2003 | 10:32 PM
Bbasso's Avatar
Default Re: (D)
Well He could ship that far if the guy pays for it... FedEx goes anywhere, Right?
Old Dec 21, 2003 | 03:40 AM
vteec's Avatar
Thanks a lot for all your help guys.............
yes fedex is available in malta....i will think about it.
So to recapitulate,
i should order the input shaft bearing and which other bearing please.....the one near the clutch housing how is it called?
once more thanking you and if i could, i would offer you
rgds,
Old Dec 21, 2003 | 06:05 AM
Dan GSR's Avatar
Default Re: (vteec)
number 16 bearing
you should also replace number 21 seal at the same time
I also reccomend you change number 17 bearing
It will also be out of spec
Old Dec 21, 2003 | 06:25 AM
Kengs's Avatar
Default Re: (vteec)
Any parts you want shipped from the US, I highly recommend the shipper use Express Mail Service (EMS) thru the post office rather than FedEx.
Old Dec 21, 2003 | 06:26 AM
CPR's Avatar
CPR
Default Re: (Dan GSR)
I've had all the bearings replaced in my tranny and mine still makes the same noise. I've even gotten the whole mainshaft assembly replaced and that didn't fix it either. I called Acura Care and one of their reps will be at my local on Dec 23rd to get a first-hand account of what's going on.
Old Dec 21, 2003 | 07:18 AM
Bbasso's Avatar
Default Re: (CPR)
And don't forget that the bearings might have spun in the case and the case could be damaged
Old Dec 21, 2003 | 07:38 AM
vteec's Avatar
SSSHHHHHHHHHHHH !! Bbasso !!
you are making me worrying ................ !! just joking mate .... i hope i will only have to replace the bearings !!
DanGsr: Thanks for the explanation ....i appreciate it a lot.
thanks once again,
Old Dec 21, 2003 | 03:41 PM
dk127's Avatar
is that really a problem? i made a post on this awhile ago before i left for school, when my clutch is in the sound goes away, but doesn't happen all the time. Am i going to have to worry about this down the road..
JaviITR
Jul 31, 2009 10:40 AM
fullyboostin
Transmission & Drivetrain
Feb 19, 2009 06:26 PM
ericlee303
Oct 6, 2005 07:55 AM
eg6turb0
Mar 1, 2005 07:33 PM
HXvtec
10
Oct 16, 2003 04:39 PM
