Removing rear backing plate and brake line
Well, like the topic says, ive searched, and found nothing. Im trying to remove the drivers side rear backing plate and ebrake cable from an 88 hf. Ive got the drums off, along with the shoes and junk. Also pulled out the strut, and got the 24mm bolt off behind the drum, but cant get the hub off to remove the backing plate bolts? What gives?
Also, ive undone the two undercarraige bolts holding the cable on, but how do i get the cable out from teh interior, basically, how do i pull it out? Its unkooked on the ebrake side, im just gonna leave hooked to the backing plate if possible, any help is appreciated, thanx.
B_Swapped93
Jan 15, 2014 07:46 PM
coot_er
Apr 15, 2007 08:05 PM
