Help!!! Temp sensor jumps too high!
Okay i was driving tonite for 20 mins then i turned it off and when it turned back on it wouldnt start for like 5 tries..on the 6th try it worked but then the engine light came on after i pumped the gas pedal
and after i drove it for 5 more mins the sensor jumped to the red line and then when i got home i heard a fuzzing sound
the radiator was just changed..what could be wrong? i popped the hood and it smelled like it was really hot
since u say ur raditor was just changed its proably just air pockets.. or not enough coolent. You need to bleed the system out.
My fan's aren't working right now.. i was sitting threw traffic for 15 minutes today my car bearly started to over heat so i doubt its your fans.. in the winter the car bearly uses them.. If your water pump was going out.. you'd be leaking coolent so thats out.. clog in the system.. highly!! doubtful thats more rare then wining the lottery
Hondadude1234
Dec 9, 2012 08:47 AM
portlandkidd157
Mar 18, 2011 05:38 AM
fdjizm
Mar 2, 2007 08:03 PM
