oil leaking
Old Dec 18, 2003 | 10:20 PM
ludelvr's Avatar
Default oil leaking
Okay, I have an oil leak somwhere, and I first thought it was from the oil filter, then I thought it was the oil pan gasket or oil return fitting, but after looking , it's none of those places. There is some oil leaking around the crank pulley though. There is a rubber lining around that area and it seems to be seeping out from there. I have to change my timing belt soon, so what else should I exactly be changing?
Old Dec 19, 2003 | 03:34 AM
Revi's Avatar
Default Re: oil leaking (ludelvr)
Could be your crank seal. Your gonna have to take of the lower cover to get to the timming belt, so youll be able to see if its leaking. Your crank pulley will be comming off too so youll be better off.
Old Dec 19, 2003 | 05:19 AM
Daemione's Avatar
Default Re: oil leaking (Revi-Ra)
There was a recall on some models for the balance shaft seal, that could be the culprit as well.
Old Dec 19, 2003 | 05:56 AM
Revi's Avatar
Also, wont hurt to check your oil pump too.
Old Dec 19, 2003 | 08:45 AM
ludelvr's Avatar
so can you guys give me a complete list of what I need to buy and replace? Also, I've done some reading on that auto tensioner and That thing is freaking expensive!! Anyway, I'd like to reuse my current one if possible.
Old Dec 19, 2003 | 11:01 AM
turbolude92's Avatar
alright, go to your mechanic and tell them you want your timing belt replaced. if they are not douchebags than they will tell you a list of stuff to be replaced. Do not just get the belt replaced. Some items will be:
Timing belt
Balance Shaft Seal
Balance Shaft seal retainer
cam seal
valve cover gasket
Crank seal
there are i believe two other belts that they replace as well. one is like a mini timing belt i cant remember what it is called and the other looks more like a v-belt
Hope this helps out.
drsab2000
Aug 8, 2015 05:47 PM
Honda-Tree
Honda CR-V & Element
Apr 16, 2014 06:37 AM
Josueneta
May 7, 2010 01:43 PM
oldskoolDA6
Nov 26, 2007 02:17 PM
immalooser
May 17, 2006 03:27 PM
