One wire hook up
Old Dec 18, 2003 | 09:19 PM
sohcvtec1995's Avatar
Default One wire hook up
How do you hook up a air fuel gauge to a one wire o2 sensor?
Old Dec 19, 2003 | 12:37 AM
Foozball26's Avatar
Default Re: One wire hook up (sohcvtec1995)
and where would these magical one wire o2 sensors be?
all a/f gauges (I'm assuming autometer you're using autometer) hook up to the wire that goes to the ecu from the sensor.
Old Dec 19, 2003 | 07:59 AM
Default Re: One wire hook up (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">and where would these magical one wire o2 sensors be?
all a/f gauges (I'm assuming autometer you're using autometer) hook up to the wire that goes to the ecu from the sensor.</TD></TR></TABLE>
it is on the o2 sensor, but he only has one wire coming from it. I have a 4 wire it i got that hooked up buy taping the o2 sensor wire(don't remember which one) But we did his one wire and the A/F gauge just sat there and looked at us.
Old Dec 19, 2003 | 09:00 AM
Devlins 91LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">and where would these magical one wire o2 sensors be?</TD></TR></TABLE>
In the header?
Obd-0 and some obd-1 cars had a 1 wire o2 sensor. My g1 b16a has two one wire o2 sensors.
Old Dec 21, 2003 | 11:02 AM
Default Re: One wire hook up (Devlins 91LS)
dose anyone know?
Old Dec 21, 2003 | 12:18 PM
mastarolla's Avatar
on one wire sensors, the one wire is the signal wire... doesnt work, check connections and if it still doesnt work then bad sensor.
Old Dec 21, 2003 | 01:04 PM
2+2=5's Avatar
Default Re: One wire hook up (mastarolla)
you should slice it to the ecu's harness, since it;s the shortest signal point, white wire for my accord, but dont quote me on that.
Old Dec 22, 2003 | 08:15 AM
Default Re: One wire hook up (2+2=5)
finally some good answers. thanks guys.
flipsyde
Feb 26, 2006 08:13 PM
JFG Kevin
Dec 9, 2005 09:22 PM
95civ
Jun 20, 2005 01:10 PM
JDMegCivic86
Oct 3, 2004 06:01 PM
