autometer air/fuel gauge??
car: 92 eg6 w/ ls swap.
alright instead of hooking the air/fuel gauge violet wire straight to the o2 i figure i just do it to the ecu for a cleaner look. i did some research and was sure that the plug was d14. hooked it up and nothing, the gauge comes on but does not read. could it be i tapped into the wrong wire or bad o2 sensor possibbly?
other info: 4 wire o2
also there was a wire connecting the d14 and a26 wire. is that suppose to be there?
Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">Unless you have a wideband in there all you're going to get is a fancy lightshow.</TD></TR></TABLE>
im running a 4-wire o2. it was working fine when i had a b16 swap. i had to then pull the b16 because i was referred to the state ref, so i decided to throw inn an LS swap so i could get it barred to the car. anyways... when i failed the first time the ref hit me for modified o2 sensor because i had the signal wire from the gauge going to the o2. thats whly i figured it will look much cleaner and the ref wont be able so say anything when i bring it back.
Re: (flipsyde)
as far as i know with the ls there is a whit with a orange stripp thats were my buddy hooked his up to on the computer. not shure the plugg number though
