i keep throwing a code 21!!!!!
Old Dec 18, 2003 | 07:36 PM
JDMlyfestyle's Avatar
Default i keep throwing a code 21!!!!!
Ok i installed a fields vtec controller. and ever since ive been throwing a code 21 (Vtec Spool Solenoid valve) and ive reset the ECU and done almost anything to fix it. but it only comes on when i hit vtec in 3rd 4th or 5th gear. I dont understand why. only thing i can think of is that i cut 1 wire from the ecu the VTM (shown in diagram below.)i cut the line from the harness i left the bare line with nothing connected on the ecu. and i connected the wire from the contoller to the harness? did i miss something? Im runnin a chipped P28 with b16 block ITR head.
Old Dec 18, 2003 | 07:54 PM
boostn420's Avatar
Default Re: i keep throwing a code 21!!!!! (JDMlifestyle)
the wire from the controller goes to the ecu and the wire in the harness is left free and ignored.
Old Dec 19, 2003 | 03:27 AM
aight ill try that hopefully it works
Jdmkids Manny
17
May 12, 2016 02:18 PM
doctorake
Mar 25, 2012 08:01 AM
joker4096
Aug 18, 2006 12:56 PM
pelotudo
Jan 30, 2002 03:02 PM
