places where people mounted there hid ballasts and kits on 94-95 tegs
places wher people mounted there hid ballasts and kits on 94-95 tegs
yep im going HID , i got a 02 tls kit with everythign i need for like 200 shipped , i ddi everythign like people said ( using the plastic 9006 things and mounting it to the light housings but idk where to put the rest o fthe hardware , i xip ties it all to the abs lines on the rigth side , but the left side idk , well where did everyone else do theres on a 94-95 , thanks
btw HID is def the way to go if you can get a good deal
I know it's not the best idea, but I just zip-tied my passenger side ballast to the front of the abs unit. Also, some people take off the bumper and run the wires through the hole on the side of the abs unit and then mount the ballast inside the fender well. I'll see if I can find a link.
Okay I found it:
http://www.team-integra.net/se...D=825
Okay I found it:
yea , the ballasts and ignitors on that kit are like half the size of my big old OEM tl ones . . .
my driver side one is on the same side as inteGSR... and my passenger side one is crazy ziptied to the upper radiator support as well as the ABS mounting bracket... i wanted to put it under the ABS unit... but i can't squeeze it in there. i wanted to mount it in the fender somewhere as suggested before, but i haven't felt like taking off the bumper again. hope this helps out.
the only problem i seem to be having is that when i hit jittery bumps, the HIDs seem to flicker... but i dunno if that's just shadows.
inteGSR: how is the passenger ballast secured? looks pretty snug in there. and nice foglights and lip...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRacer93 »</TD></TR><TR><TD CLASS="quote">
it's velcroed to the coolant reservoir and also on the bottom to the metal. it's also held by zip ties
</TD></TR></TABLE>it's velcroed to the coolant reservoir and also on the bottom to the metal. it's also held by zip ties
ATL-R
Jun 8, 2003 11:18 AM
