got cams, do i need adjustable cam gears?
Old Dec 18, 2003 | 05:23 PM
slowacura's Avatar
Default got cams, do i need adjustable cam gears?
i got the type r cams from that HT deal. i'm going to buy a VAFC. how important are adjustable cam gears?
Old Dec 18, 2003 | 05:34 PM
Havokmkr's Avatar
Default Re: got cams, do i need adjustable cam gears? (inteGSR)
Very important, if you plan on being able to tune. Stock cam gears are non-adjustable.
Old Dec 18, 2003 | 05:35 PM
mr.beeks's Avatar
just to get the more HP out of your new cams
@ the dyno you will need it
if not just drive around with the missing power...
Old Dec 18, 2003 | 07:27 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inteGSR &raquo;</TD></TR><TR><TD CLASS="quote">i'm going to buy a VAFC.</TD></TR></TABLE>
I assume you'll be dyno tuning, in which case it would save you time and money to have the sprockets adjusted at the same time, rather than installing and tuning them at a later date.
Old Dec 18, 2003 | 07:30 PM
XtremeCarTuner's Avatar
You might as well buy adjustable cam gears. Since you are putting on cams, you should do it now and dont have to worry about it in the future. I'll save you the grief anyways in the long run and especially when you want to tune your car. So definately look up a good set of gears.
Nihilation's Avatar
Just out of curiousity, do you have to have a cut valve cover in order to adjust the cam gears?
Old Dec 18, 2003 | 08:00 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Nihilation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihilation &raquo;</TD></TR><TR><TD CLASS="quote">Just out of curiousity, do you have to have a cut valve cover in order to adjust the cam gears?</TD></TR></TABLE>
No, but removing and reinstalling the cover to make adjustments after each pull is not really practical. I always suggest buying a cheap used cover to cut and use for tuning, leaving the original one un-cut and able to prevent debris from coming in contact with the belt and sprockets.
Old Dec 18, 2003 | 09:13 PM
patdemps's Avatar
Default Re: (Padawan)
Definately get some cam gears. Do it all right the first time.
Your also going to need to find a valve cover to cut for the dyno. Its always good to have an extra one hanging around anyway.
JDAMC
Mar 8, 2007 05:14 AM
RC's ride
Dec 11, 2005 03:52 PM
redGSRguy
Oct 2, 2003 10:58 PM
NVBAM
May 21, 2003 09:00 AM
acatak
Jul 13, 2002 02:19 PM
