5-Lug Crx??
Old Dec 18, 2003 | 12:31 PM
vtectommyd's Avatar
Default 5-Lug Crx??
Just curious as to if and how it can be done. I searched and couldnt find anything. Wanted to do this due to wheels and bigger brakes. If not does anyone know what big brake kit there are for a 91 crx. There was a copper colored crx in honda tuning i belive a couple months ago wiht some huge brake but cant remember what they where. any info would be great
Old Dec 18, 2003 | 12:33 PM
kid-honda's Avatar
Yes it can be done and its pretty easy.
Search, their are a few posts with pics and how to.
If you cant find any I have some pics.
Old Dec 18, 2003 | 01:35 PM
YumVTEC's Avatar
Default Re: (kid-honda)
you use 90-91 civic ex knuckles up front, 5-lug ITR hubs, calipers, rotors, and you have to either use an ITR wheel bearing and machine the EX knuckle so it fits, or use an EX wheel bearing and machine the ITR hub to fit it. in the rear you need the whole trailing arm assembly from the ITR with hubs, calipers, rotors, etc... if it's going on a cr-x then I think 90-91 CR-X Si e-brake cables will work for you. you might need the ITR cables though just in case.
Old Dec 18, 2003 | 03:03 PM
bryant's Avatar
Default Re: (YumVTEC)
It all bolts on. Just need longer ebrake cabels if you dont have rear disk.
Old Dec 19, 2003 | 11:18 AM
vtectommyd's Avatar
Default Re: (Bryant)
i searched and couldnt find any thing does anyone have a link or pics of the 5lug on a crx
Old Dec 19, 2003 | 12:05 PM
Mr Furball's Avatar
Default Re: 5-Lug Crx?? (vtectommyd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtectommyd &raquo;</TD></TR><TR><TD CLASS="quote">Just curious as to if and how it can be done. I searched and couldnt find anything. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=431607
https://honda-tech.com/zerothread?id=207764
https://honda-tech.com/zerothread?id=565420
Here are just 3 but there are others.
Old Dec 19, 2003 | 12:35 PM
vtectommyd's Avatar
Default Re: 5-Lug Crx?? (FURBALL B-16)
so basically i just swap all the type r stuff and get a camber kit for the front, or i can use 90-91ex spindles get the trype r hub machined to fit and press the type r hub in. is this correct? if so whats different about the 90-91 ex hubs compared to the 90-91 si hubs? also in the rear i couldnt find a clear example. should i swap the whole setup including the rear shocks since the crx is a u type joint and the type r is a pinch type, or leave the stock lca and just swap the trailing arm/brake assem.?
thanks
Old Dec 19, 2003 | 12:43 PM
bryant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant &raquo;</TD></TR><TR><TD CLASS="quote">It all bolts on. Just need longer ebrake cabels if you dont have rear disk.</TD></TR></TABLE>
Old Dec 19, 2003 | 01:16 PM
vtectommyd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant &raquo;</TD></TR><TR><TD CLASS="quote">It all bolts on. Just need longer ebrake cabels if you dont have rear disk.</TD></TR></TABLE> im just trying to iron out the details before i start cuz in someone else post you said it wasnt all bolt ons and i am still curious as the the rear shocks
Old Dec 19, 2003 | 02:38 PM
YumVTEC's Avatar
Default Re: (vtectommyd)
you will use your civic upper and lower control arms in the front and back. you can't use the Civic DX/HF/Si/LX etc... knuckle because the ITR caliper will not bolt properly to it. even with the EX caliper you have to use washers and rig it to make it work properly. bryant almost did it on his cr-x, and he had all the parts all ready to go but then changed his mind (like he usually does on modding his cars, heh...).
Old Dec 19, 2003 | 03:51 PM
bryant's Avatar
Trevor thats the hard way. I was doing it all wrong. It all bolts up. Just go back through the links the guy posted above and do a bit of reading. You just need the Integra tie rods and your pretty much good to go. Simple as that.
Old Dec 19, 2003 | 04:43 PM
Drake71400's Avatar
they make a hub kit... i dont have the site on me im at my parents house but there is a upgrade hub kit that is made for your car... just look around for one.. or a place that sells upgraded hub kits..
Old Dec 20, 2003 | 02:37 PM
payneth's Avatar
good luck
Old Dec 20, 2003 | 03:44 PM
f@sth@tch89's Avatar
Default Re: (Payneth)
Can you use the 5 lug hubs off of the honda odysess(sp?)?????
Old Dec 21, 2003 | 12:27 PM
vtectommyd's Avatar
Default Re: (fasthatch89)
thanks for the help im guessing im just gonna bolt the type r stuff on get alignment kit for the front and rear to make sure everythgin is straight
Old Dec 23, 2003 | 07:01 AM
bryant's Avatar
Thats all find and dandy, But you need 94-01 Integra tie rods and longer ebrake cables if you dont have rear disk. then your set.
Old Dec 23, 2003 | 10:49 AM
vtectommyd's Avatar
do i need the just the tie rod or tie rod and end?
Old Dec 24, 2003 | 06:00 AM
bryant's Avatar
probley should get the ends too, Just to make sure. Or try it with out them and then add them if needed.
rex714
Aug 25, 2009 06:43 AM
EXEGCoupe93
Aug 6, 2007 04:31 AM
91rexman
Jun 30, 2006 12:05 PM
PassThatShi7
Jun 15, 2006 01:40 AM
Solscud007
Dec 21, 2004 01:48 PM
