CRX Climate controls
Old Dec 18, 2003 | 09:28 AM
Robb's Avatar
Default CRX Climate controls
Would the climate controls from an 88 Civic wagon, the 5 door hatchback fit an 88 CRX? Thanks.
Old Dec 18, 2003 | 09:35 AM
EL Vap133's Avatar
Default Re: CRX Climate controls (Robb)
You would have to do some customizing for it to fit and work, I have never seen Civic climate controls in a CRX though. I think someone has used either prelude or Accord climate controls before...
Here is a guy that used CRX climate controls in his Civic: https://honda-tech.com/zerothread?id=243975
Old Dec 18, 2003 | 10:14 AM
Jet Black's Avatar
Why would you want to do that?
The CRX has the advantage of electronic cotnrols...just find another control pannel if yours is broken...shouldnt be too hard as those cars are dissintegrating.
Old Dec 18, 2003 | 10:28 AM
Robb's Avatar
Default Re: CRX Climate controls (Jet Black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">...shouldnt be too hard as those cars are dissintegrating.</TD></TR></TABLE>
Yes they are dissintegrating, along with there climate controls, they are hard to come by.
Old Dec 18, 2003 | 10:33 AM
Jet Black's Avatar
Not really....just get a cracked one.
The non cracked ones are expensive as hell...but you should be able to find one with a cracked face for pretty cheap...then you can swap your face onto it.
Why not fix your control box?
It will require a fair bit of modification to get the civic controls in as they are manual and you will need to adapt your crx for taht. It will bolt right in tho.
Old Dec 18, 2003 | 10:47 AM
EL Vap133's Avatar
Some guy here on HT made a metal bracket for our climate controls, I can't find the damn post though....
Old Dec 18, 2003 | 11:24 AM
Jet Black's Avatar
Default Re: CRX Climate controls (EL Vap133)
Dont think you need one for the civic controls...I'm using a CRX dash and metal framing in my civic, fit fine with the civic controls.
Old Dec 18, 2003 | 11:32 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">Dont think you need one for the civic controls...I'm using a CRX dash and metal framing in my civic, fit fine with the civic controls.</TD></TR></TABLE>
He wants to use Civic controls in his CRX cause his might be broken. This guy on HT made a medal bracket so that you can still use your CRX controls...
Old Dec 18, 2003 | 11:34 AM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">Not really....just get a cracked one.
It will require a fair bit of modification to get the civic controls in as they are manual and you will need to adapt your crx for taht. It will bolt right in tho.</TD></TR></TABLE>
From someone who has fixed a few cracked CRX control panels, you CANT just replace the face. The face is also the outer housing.
I agree with the other posts though, just buy a cracked one at the J-yard or off ebay and JB weld it. And to use the civic panel you would have to convert the actuators to cables not servos. Maybe try a 2G teg control panel instead.
HTH
Old Dec 18, 2003 | 11:56 AM
Jet Black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
He wants to use Civic controls in his CRX cause his might be broken. This guy on HT made a medal bracket so that you can still use your CRX controls...</TD></TR></TABLE>
Explain that? From what I understand you know whats wrong with his controls and he can fix it with a metal bracket?
Old Dec 18, 2003 | 11:59 AM
EL Vap133's Avatar
Explain that? From what I understand you know whats wrong with his controls and he can fix it with a metal bracket?</TD></TR></TABLE>
if I could find the post I would be able to show you...
Old Dec 18, 2003 | 12:20 PM
Robb's Avatar
This CRX has no controls in the car, the car is stripped. Jus looking for an easy fix as I found some Civic controls, but have not been able to find any decent CRX controls.
Old Dec 18, 2003 | 12:22 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robb &raquo;</TD></TR><TR><TD CLASS="quote">
This CRX has no controls in the car, the car is stripped. Jus looking for an easy fix as I found some Civic controls, but have not been able to find any decent CRX controls.</TD></TR></TABLE>
Ahhh ok, no wonder. On that same post that I can't find, I believe some guy used old school prelude climate controls on his crx. I wish I could find the damn post, I tried every word I could possibly use in the search feature...
Old Dec 18, 2003 | 12:41 PM
4crx4me's Avatar
If the car is STRIPPEd you're still gonna need the underdash wire harness to make the controls work. Try looking for a 2G teg in the junkyard. The controls are very similar to a CRX's.
HTH
Old Dec 18, 2003 | 12:42 PM
EL Vap133's Avatar
I found it!!!! Here is the post!!
https://honda-tech.com/zerothread?id=654417
Somewhere in there, this guy used Accord or Prelude climate controls, just scroll through it...
Old Dec 18, 2003 | 08:55 PM
Red_Si's Avatar
looks good
Old Dec 19, 2003 | 08:02 AM
EL Vap133's Avatar
Default Re: CRX Climate controls (Red_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_Si &raquo;</TD></TR><TR><TD CLASS="quote">looks good</TD></TR></TABLE>
The custom bracket or the Accord controls?
Old Dec 19, 2003 | 11:26 AM
Red_Si's Avatar
custom bracket, even tho the accord controls aren't that bad either.
Old Dec 19, 2003 | 11:38 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_Si &raquo;</TD></TR><TR><TD CLASS="quote">custom bracket, even tho the accord controls aren't that bad either.</TD></TR></TABLE>
Yeah, it allows you to use your broken climate controls.
WestSideRain
Jun 24, 2009 06:38 PM
B-serious
11
Jul 26, 2006 08:55 AM
SiMateoAko
Jan 23, 2006 04:31 PM
iNetForce
Apr 3, 2004 07:34 PM
miahmouse
Mar 7, 2003 01:13 PM
