no clutch pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 »</TD></TR><TR><TD CLASS="quote">Look at the slave and master. Check fluid levels.
If there IS fluid in it, then you neet to bleed it.</TD></TR></TABLE>
yep
check inside under the driver's dash where the clutch pedal connects to the "rod" on the master cylinder...if it's wet down there it's your master.....on the slave cylinder, move the rubber boot around and inspect around the area for leaking fluid....good luck
yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">If there is black, nasty fluid on the inside of your car where your clutch pedal meets the firewall, your clutch master cylinder is bad.</TD></TR></TABLE>
beat me too it
beat me too it
If none of those work, im pretty sure its your pressure plate, same thing happen to mine, i changed the SC and the MC, brand new parts, and of course i bleed it too, and it still no pressure, but check your pressure plate.
mine had a slooooooow leak and the clutch drived horribly. we noticed dirt build up under the slave cylinder and realize it had a small leak. I changed it out in 25 min and its all good eversince
i also have this problem, i bleed it with ate super blue fluid, checked all over for leaks, bleed it again. and i still cant figure out why mine is soft. it only does it sometimes mostly when its really hot.
well i dont have any fluid in my clutch holder(the thing right beside my brake booster) so i put some DOT 3 in it and it is a tiny bit better enough to drive i to the shop to get my car painted. And i bought a slave cynlinder yesterday hopeful;ly it shjould work
