how do you drain ps fluid?
Old Dec 17, 2003 | 09:30 PM
david90's Avatar
Default how do you drain ps fluid?
how do you drain ps fluid? Is there a drain plug? mine is 5th gen v6.
Old Dec 18, 2003 | 03:09 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: how do you drain ps fluid? (david90)
On my 5th gen 4cyl I took a hose that was connected to the resevour (which hose I can't remember) and put the other end in a container. Then I started the car and turned the steering wheel back and forth until nothing came out. Then I refilled the resevour, turned the car on again and turn the steering wheel back and forth to bleed all the air out. I believe that was the way I did it, it's been a little while and I don't have my helms. Anyways, hope this helps.
Old Dec 19, 2003 | 01:52 PM
CmptchAV6's Avatar
Default Re: how do you drain ps fluid? (TouringAccord)
turning the car on to drain the fluid can be risky though if you leave it on too long the pump can burn up if it has no fluid going through it. Besides powersteering fluid there is no other lubricant in the powersteering pump
Old Dec 21, 2003 | 02:20 AM
jakester's Avatar
Turkey baster. I sucked out old fluid and replaced with new, keeping in mind that there is still old fluid in hoses. I did this twice and everything looks good.
Old Dec 25, 2003 | 01:43 PM
accordking's Avatar
Default Re: how do you drain ps fluid? (jakester)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jakester &raquo;</TD></TR><TR><TD CLASS="quote">Turkey baster.</TD></TR></TABLE>
If you have access to a compressor use a Vaculla.
philkehn
Nov 19, 2008 03:12 AM
britishdude
Dec 20, 2007 07:58 AM
dust_101
Jun 12, 2006 08:33 AM
Silvteg95
Jul 30, 2005 08:54 PM
pineapplemike
Oct 13, 2003 09:32 AM
