Troubleshoot: Transmission - gears jamming
Old Dec 17, 2003 | 07:05 PM
sleeprhatch's Avatar
Default Got a tranny question
Before I put my car away for the winter, I was driving to a friends house when shifting into 3rd gear became stiffer than usual. I did not really pay any attention, so I kept driving. Then all of a sudden I could not get it into 1st, 3rd or 5th gear. I could only go into 2nd, 4th and reverse. It almost seem like the linkage was jammed. Even neutral did not feel like neutral. After driving home in 2nd gear I tried one last time to run the shifter in the gears..... all the gears came back. WTF!!! Anyone else ever have this happen to them. I think it is syncro's or linkage inside the tranny. It has a new clutch and flywheel with less than 6,000 miles on it. This is a 1999 JDM B18c Itr block and tranny. I check the linkage and nothing looks out of the ordinary. What do you think it may be?
Modified by sleeprhatch at 11:27 PM 12/17/2003
Old Dec 17, 2003 | 07:53 PM
Default Re: Got a tranny question (sleeprhatch)
anyone?
Old Dec 17, 2003 | 08:10 PM
nightrider's Avatar
when's the last time you changed your tranny fluid?
Old Dec 17, 2003 | 08:34 PM
Default Re: Got a tranny question (nightrider)
1 month before this happening
Old Dec 17, 2003 | 08:36 PM
nightrider's Avatar
wow, then it must be syncros or something like that. maybe it has something to do with your flywheel and clutch?
Heisdan's Avatar
well bad news.. but yeah I had this happen before I completely threw the tranny out.. it froze on me.. drove decent for a while.. then it froze again and woulnd't come undone.. my best guess is you part of a gear off.. and its running around in there..
Old Dec 17, 2003 | 08:37 PM
JjuuN R's Avatar
not a clue
just give the dealership and call and ask? not sure of what else to do
Old Dec 18, 2003 | 07:45 PM
Default Re: ([JUN]+R...)
anyone else before I rip this thing apart?
Old Dec 18, 2003 | 11:26 PM
Black R's Avatar
25 Year Member
Default Re: (Heisdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heisdan &raquo;</TD></TR><TR><TD CLASS="quote">well bad news.. but yeah I had this happen before I completely threw the tranny out.. it froze on me.. drove decent for a while.. then it froze again and woulnd't come undone.. my best guess is you part of a gear off.. and its running around in there..</TD></TR></TABLE>
He's right. You've likely broken a tooth off one of your gears or the final drive and it's floating around in your tranny getting jammed in between ****.....
Time for a rebuild..... You may want to consider upgrading the final drive, clutch, flywheel, and lsd while you're in there.....
Old Dec 19, 2003 | 03:41 PM
Default Re: (Black R)
thanks 4 the replys
Old Dec 19, 2003 | 04:16 PM
Dan GSR's Avatar
Default Re: (sleeprhatch)
could also possibly be this
MT SHIFT ROD-SHIFT HOLDER
bent or loose
either way...fix it soon before it does more damage
civais
12
Apr 19, 2006 12:51 PM
v4lu3s
Feb 14, 2005 06:13 AM
Rod.
Nov 11, 2004 09:05 PM
fkncivic
Jun 30, 2003 06:53 PM
Jesse H
Aug 20, 2002 05:04 PM
