Can I Still Go Long Driving with a Turbo R?
Old Sep 21, 2001 | 12:22 PM
CPR's Avatar
CPR
Default Can I Still Go Long Driving with a Turbo R?
Are there things a Type-R won't be able to do if it's got a Turbo? To simplify the question, let's assume I'm only running either 6 or 7 pounds of boost
[Modified by CPR, 4:26 PM 9/21/2001]
Old Sep 21, 2001 | 01:05 PM
CheezeFrog's Avatar
Default Re: Can I Still Go Long Driving with a Turbo R? (CPR)
What did you have in mind? I can think of several things a turbo Type-R won't be able to do:
  • Pass visual inspection
  • Lose to stock Camaro SS
  • Stay under factory warranty (unless you know somebody who knows somebody)
I'm sure there are other things I've missed too...
Old Sep 21, 2001 | 01:11 PM
CPR's Avatar
CPR
Default Re: Can I Still Go Long Driving with a Turbo R? (CheezeFrog)
I was open to anything but my 1st concern was being able to take a 10 hour road trip
Old Sep 21, 2001 | 01:38 PM
GoodFella's Avatar
Unfortunate Clevland Sports Fan
im no expert but i think if you ran a low boost on the long trip like say 5 psi you should be fine but you might want to ask some one with that setup...my only concern would be your engine might get a little too hot so might have to take a break evey few hours,....my bro drove 6 1/2 hours on 4 or 5 psi on a jrsc and he did nt seem to have any problems.
Old Sep 21, 2001 | 02:02 PM
MackSpeed-616's Avatar
Default Re: Can I Still Go Long Driving with a Turbo R? (True Soprano)
on the highway you are not in boost 90% of the time. drivin on the highway is very is on the car.
Old Sep 21, 2001 | 02:17 PM
SpoonCivic's Avatar
New User
Default Re: Can I Still Go Long Driving with a Turbo R? (TurboR616)
ull b fine. just dont boost higher then 8psi..do oil changes (good synth) every 2000-3000km
Old Sep 21, 2001 | 02:42 PM
IntegraT's Avatar
I wouldn't risk it, it's such a beautiful NA motor. For the 3k you'll spend
Old Sep 24, 2001 | 10:26 AM
CPR's Avatar
CPR
Default Re: Can I Still Go Long Driving with a Turbo R? (IntegraT)
I was so set in going to an NA Spec B setup until I found out that running a turbo with modest boost (7-8psi) isn't a big risk as it seems. Finding a great groupbuy at importparts.com has also gotten me thinking twice. What kind of whp numbers should I expect with a stock boost DRAG turbo kit with adequate tuning and everything else stock (internals, exhuast, etc...)???
[Modified by CPR, 2:29 PM 9/24/2001]
Old Sep 24, 2001 | 10:47 AM
Double 06's Avatar
New User
if you don't do anything else, atleast upgrade the turbo from ben to a 3" themal for 500$,, without it you will be really choking your turbo at 8psi....
Old Sep 24, 2001 | 10:55 AM
CPR's Avatar
CPR
Default Re: Can I Still Go Long Driving with a Turbo R? (Double 06)
Ok, let's say I do upgrade to the 3" thermal exhuast...what kind of power, in terms of whp, will I be seeing?
Old Sep 24, 2001 | 11:28 AM
spyder's Avatar
New User
The turbo only boosts when you really mash on the gas, so like TurboR616 said, it is no problem so long as you just cruise. No 140mph for 10 hours crap (not to mention, you'd be stupid to do that anyway).
Old Sep 24, 2001 | 11:55 AM
Double 06's Avatar
New User
Default Re: Can I Still Go Long Driving with a Turbo R? (spyder)
i would say at 8psi, with drag kit, and themal 3 inch.
250+ is easily within reach, but you will be really be running some high fuel pressures.
Drake_ep3
Sep 5, 2008 07:29 PM
prabtej_si
Jan 25, 2005 09:02 PM
ShuaiGuy
Jul 13, 2004 06:30 PM
Madrat888
Jun 20, 2004 09:35 PM
Brandon Chun
Feb 4, 2002 08:04 AM
