remove crossmember if i go B?
Old Dec 16, 2003 | 07:52 PM
USDMMARK's Avatar
Default remove crossmember if i go B?
do i have to will it cause a problem? hear so many bad things about it figured id ask
Old Dec 16, 2003 | 08:15 PM
Cm91h22a's Avatar
sometimes the tranny will fit sometimes you just have to remove the front transmission bracket that is on the front crossmember. That is all.
Old Dec 16, 2003 | 09:59 PM
dingusjt's Avatar
Default Re: (Cm91h22a)
what mounts are you using??
Old Dec 16, 2003 | 10:58 PM
Origin's Avatar
Default Re: (dingusjt)
with my hasport mounts i had to remove my front mount. i just got a sledge hammer and broke the welds. good work out.
Old Dec 17, 2003 | 07:13 AM
USDMMARK's Avatar
Default Re: (Origin)
lol thanks
Old Dec 17, 2003 | 07:31 AM
dingusjt's Avatar
Default Re: (ORIGIN[AL])
yeah removing your entire crossmember for that isn't too smart
Old Dec 17, 2003 | 08:01 AM
EL Vap133's Avatar
Default Re: remove crossmember if i go B? (ORIGIN[AL])
You can remove it to install the motor but there is no way that you can remove it completely cause you will crash...
Old Dec 17, 2003 | 09:58 AM
ScottEK's Avatar
Default Re: remove crossmember if i go B? (EL Vap133)
Mod it and make a front mount work
HCP 4 mount kit
Old Dec 17, 2003 | 10:03 AM
neutron91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">You can remove it to install the motor but there is no way that you can remove it completely cause you will crash...</TD></TR></TABLE>
no ****... you would be all over the road
p2pwn
Jan 16, 2009 07:56 AM
tweeter
12
Apr 20, 2007 09:31 AM
sik94hatch
Apr 14, 2006 05:16 PM
jdub db8
Nov 26, 2004 09:30 PM
