new radiator, but still overheats
Old Sep 21, 2001 | 11:35 AM
jdmteg's Avatar
New User
Default new radiator, but still overheats
I had a problem with my radiator where it was leakin coolant. It overheated twice while my radiator was messed up. But I replaced the radiator with a new one and it worked fine, but last night when it rained I turned on the A/C and after a while I noticed it started overheating again. What could it be? Is the head warped and is this why its overheating?
Old Sep 21, 2001 | 11:41 AM
5 Liter Eater's Avatar
Default Re: new radiator, but still overheats (jdmteg)
Could be a head gasket. Could also be that your A/C is overcharged. I have seen both of those cause overheating. If you start to overheat and you turn on the heater and it doesn't get cold, you have a blown head gasket.
Old Sep 21, 2001 | 11:54 AM
randomwalk101's Avatar
I'd also like to add that it could be your thermostat...fairly cheap and easy to replace so you might want to give it a shot first.
Old Sep 21, 2001 | 12:01 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: new radiator, but still overheats (randomwalk101)
try thermostat
Old Sep 21, 2001 | 01:37 PM
ndustryalGSR's Avatar
Default Re: new radiator, but still overheats (vtecvoodoo)
It's most likely the thermostat -- should be ~$9 at a local parts store.
Old Sep 21, 2001 | 01:52 PM
Chris's Avatar
Default Re: new radiator, but still overheats (ndustryalGSR)
Check the water Pump. They are made to leak when they wear out. Check where its leaking from. Is it all splattered on the underside of the hood above the Belts? If so...Water Pump.
Old Sep 21, 2001 | 07:16 PM
TKBLAZER's Avatar
Default Re: new radiator, but still overheats (Chris)
did u ever replace the radiator hoses? my car was leaking coolant slowly after swapping in a new radiator...i got new hoses and everything is now fine.
Old Sep 22, 2001 | 01:30 AM
jdmteg's Avatar
New User
Default Re: new radiator, but still overheats (TKBLAZER)
I already replaced the thermostat and no I haven changed the hoses.
crx_goddezz
Classic Hondas
Nov 30, 2010 04:43 PM
94ls
May 17, 2009 03:23 PM
bomber19
Aug 5, 2007 06:57 PM
dynastix9
Dec 18, 2005 06:33 AM
prplecivic94
14
Jul 15, 2004 05:26 AM
