Speedo cable help
Old Dec 16, 2003 | 04:53 PM
onePOINTsix's Avatar
Default Speedo cable help
well were swaping a Z6 into my friend (PolicyVote on here) and i have absolutly no idea how to get the damn cable out. need some help here, i already broke the little metal tab off by accenent and we have a new cable on order... have any ideas? also for getting the axels out, do i HAVE TO take the spindle nuts off to get the axels out of the tranny?
Old Dec 16, 2003 | 05:32 PM
Default Re: Speedo cable help (Sideout)
TTT for the sake of VTEC y0!
Old Dec 16, 2003 | 05:43 PM
Alan Wil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">well were swaping a Z6 into my friend (PolicyVote on here) and i have absolutly no idea how to get the damn cable out. need some help here, i already broke the little metal tab off by accenent and we have a new cable on order... have any ideas? also for getting the axels out, do i HAVE TO take the spindle nuts off to get the axels out of the tranny?</TD></TR></TABLE>
On the speedo cable...Do you have a service manual? If not it's a good thing to have.
On the axles, unless you unbolt the entire suspension you wil be hard pressed to get the axles out without damging something.
Old Dec 16, 2003 | 05:59 PM
Lo-Buck EF's Avatar
Default Re: Speedo cable help (Alan Wil)
u def. have to take the front sus apart t get the axles out.
disconnect the lower control arms from either the knuckle via the balljoint or from the car. also, disconnect the lca from the shock. its real easy. to get the axle nuts loose, ur gonna need a breaker bar and a torque multiplier (long pipe) if they havent been off recently. and be sure to bend up the tabs on teh nuts that keep them from backing off the axle. once there only in teh trans, pry them out of the trans with a long screw driver.
as for the spedo cable, theres a metal clip that goes around it. pull that off, then u should be able to pull the cable straight out. u may pull the vss (veichle speed sensor) out of the trans too, but thats not a big deal. just make sure u dont pull the cable out of the cluster too. i did that. pain in the azz.
-spenc
Old Dec 16, 2003 | 06:37 PM
Default Re: Speedo cable help (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">as for the spedo cable, theres a metal clip that goes around it. pull that off, then u should be able to pull the cable straight out. u may pull the vss (veichle speed sensor) out of the trans too, but thats not a big deal. just make sure u dont pull the cable out of the cluster too. i did that. pain in the azz.
-spenc</TD></TR></TABLE>i think i broke the tab oh well, i'll try to get it out tommarow in sunlight and not 5000 candle power floodlamp, i'll try to post up some pic if someone wanted to see how the swap goes
edit: wait unclip it from teh cluster and run it out of the firewall? would that work?
Old Dec 16, 2003 | 07:28 PM
TTT for the late nighters
Old Dec 17, 2003 | 12:27 PM
TTT
Old Dec 17, 2003 | 04:36 PM
Lo-Buck EF's Avatar
i suppose u could pull t through. i think if u pull the cable out of the trans, it'll come out one way or the other. pullin it via the cluster is a pain. but it is an option. look around the cable to vss and see if there is a little metal clip (not tab.) if the clip is still there, pull it off. if u did that already, spray some wd-40 or pb blaster in there and try again. also, there is (i think) a metal sleve that goes over the cable to hold it in with a bolt that threads into the case. im sure u got that off, but just incase u didnt.......
philkehn
Nov 19, 2006 10:08 AM
Devo94ac
Oct 15, 2006 08:13 AM
BigDawwg6969
Feb 25, 2006 05:35 PM
drjondurst
Mar 29, 2003 06:34 PM
Snail Tuning
Jan 17, 2003 04:53 AM
