Im fucked..
Old Dec 15, 2003 | 09:28 PM
grandmasterflex's Avatar
Default Im fucked..
My springs wont come off my struts. My spring compressors are to thick to get in between the coils so I cant compress them to get them off/on. What can I do?
Old Dec 15, 2003 | 09:37 PM
jdmoutlaw's Avatar
Default Re: Im fucked.. (whole9)
lay the spring on the ground put your foot on it and losen the nut with a impact. Do this away from he car because strut is going to shot out. Make sure you stand clear
Old Dec 15, 2003 | 09:45 PM
Default Re: Im fucked.. (jdmoutlaw)
Aight ill try that :D ill post the results soon....
Old Dec 15, 2003 | 10:10 PM
bryant's Avatar
dont touch the nut after that, its going to be H-O-T!
Old Dec 15, 2003 | 10:31 PM
JonGP4's Avatar
Default Re: Im fucked.. (Bryant)
yup.. but hope your lowering springs are already short enough to fit over your struts without compressing them otherwise your royaly fucked.. you won't have a ride
Old Dec 16, 2003 | 12:45 AM
jdwebmaster's Avatar
hmmm.... wonder why he hasn't replied back yet. maybe the spring went into his face. The only time i had problems with my spring compressor was the dust cover was in the way.
Old Dec 16, 2003 | 01:04 AM
91civicDXdude's Avatar
i've never once used a spring compressor and the spring has never shot off.
Old Dec 16, 2003 | 02:47 AM
K20EF8's Avatar
hold the strut agaisnt a tire to absorb and prevent the spring from flying off
Old Dec 16, 2003 | 04:39 AM
sircrxracer's Avatar
That's how I do it too.... but I shoot the spring into a spare tire. Rob
Old Dec 16, 2003 | 05:53 AM
IwantaGlock18's Avatar
Default Re: Im fucked.. (sircrxracer)
If I can't get a hold of a spring compresser, I've always loosen the nut while the strut is still in place and the car on the ground. That way when you jack up the car, the spring decompresses on its on.
Old Dec 16, 2003 | 06:11 AM
Alan Wil's Avatar
Default Re: Im fucked.. (dsman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsman &raquo;</TD></TR><TR><TD CLASS="quote">If I can't get a hold of a spring compresser, I've always loosen the nut while the strut is still in place and the car on the ground. That way when you jack up the car, the spring decompresses on its on.</TD></TR></TABLE>
Out of all the ideas presented so far the above is the safest way to decompress a spring without a spring compressor. You can do the same with the strut off the car, but there is considerable amount of stored kinetic energy in the spring.
Old Dec 16, 2003 | 06:24 AM
slow hatch's Avatar
Default Re: Im fucked.. (Alan Wil)
Do it on the car. Loosen the bottom of the strut, then remove the center nut off the shock without taking the top hat thingy off. This way it just releases the spring and strut from the black top thingy, no spring compresser needed. Worked every time I put someones coilovers on. Kinda hard to explain.
Old Dec 16, 2003 | 08:27 AM
Outsane's Avatar
Default Re: Im fucked.. (slow hatch)
this thread is about comparing ways to be ghetto!..all we need now is advice on how to cut springs....
but I have to say that I have done it before...
Old Dec 16, 2003 | 08:37 AM
WuShu's Avatar
New User
Default Re: Im fucked.. (Outsane)
another ghetto way,
take tire off
put a jack under control arm
jack up and compress spring
undo bolts
slowly release pressure in jack
voila
important tip* watch your face
Old Dec 21, 2003 | 10:10 PM
Vinceg99's Avatar
Default Re: Im fucked.. (WuShu)
Well heres another ghetto way for you BUT to put them ON.....
See I was running into this same problem where the spring compressor wouldnt fit with the dust boots and my neuspeed/Konis and Neuspeed sport springs and since they have a shorter shaft they had to be comprssed in order to be put on.
So what I did was I used the spring compressor on the just the spring itself compressed it to how far it needed to be compressed, grabbed some tape rope (rope that is very strong and basically looks like tape) wrapped it around all of the compressed springs tied it up really good (also went around a few times) and then took off the spring compressor SLOWLY so the rope then held it compressed put it over my shock bolted the top hat on and then untied them and viola!!! Worked like a charm! Now this may not be the safest but I just wanted the damn things mounted and it worked great for me.
Old Dec 22, 2003 | 08:53 AM
y49crxsi's Avatar
Default Re: Im fucked.. (Vinceg99)
I just get the top nut loose almost to the point that the spring will shoot off, then i get the drill with the correct socket on the end, put my body wieght on it, and just slam teh drill, so that my body absorbes all the pressure, doesnt hurt at all, jsut kidna scares you when i tdoes go. You ahve to get the nut almsot all the way off, so that the shaft doesnt turn when you turn the nut without holding it. ANd with lowering splrings, its ussually alot easier to put on, considering htey are a but shorter. It helps to have two people though.,
Old Dec 22, 2003 | 08:59 AM
kranked91dx's Avatar
EDIT : **** I forgot to add the quote of JDMoutlaw.... with the impact and the strut... one feet over the strut... anyway go up tha page and read his post.
do it that way, but add a tire laying flat on the ground just behing the strut and one in front of the impact... those two tire will absorb the energy released by the tire....like this: ()-------() the () represent the tire, and the ---- represent the shock with the impact...
keep your head out of tha way man, those thing can kill pretty easy... imagine receiving a shot of an Easton Aluminium bat in the face, except that way, it's comming with a 450 pound swing...
good luck
Kranked
masterEF
11
Nov 16, 2010 01:18 PM
Sean @ ESG
Suspension & Brakes
Nov 23, 2005 01:22 PM
hondaracing1
11
Mar 24, 2005 06:24 PM
01nhbgsr
Feb 23, 2004 03:47 PM
crxmadman
Nov 12, 2002 04:33 PM
