Grr, test only smog sentence in CA, wondering if p&p will pass?
Old Dec 15, 2003 | 03:55 PM
obd2gsr's Avatar
Default Grr, test only smog sentence in CA, wondering if p&p will pass?
Hey everybody, thanks in advanced for looking.
I currently own a '98 gs-r with a p&p head. other mods are simple bolt ons: JG carb approved 4-2-1 header, custom 2.25 exhaust to itr muffler, itr cams, skunk2 intake manifold, fpr, and jdm itr ecu. Stock bottom end, and stock everything else, including suspension.
I am going to reinstall the stock FPR, exhaust manifold, b-pipe and muffler, and put on the stock ECU.
My questions are, will the skunk2 intake manifold fail visual? I think the Skunk2 intake manifold is pending CARB legality, but has the design been changed since the first generation of these manifolds?
Also, will the p&p head pass smog in CA?
Thanks for any input. Appreciate it.
Old Dec 15, 2003 | 04:25 PM
Teknic73's Avatar
Default Re: Grr, test only smog sentence in CA, wondering if p&p will pass? (obd2gsr)
helllllll...n0! sorry pall
Old Dec 15, 2003 | 04:28 PM
fuck honda-tech's Avatar
Default Re: Grr, test only smog sentence in CA, wondering if p&p will pass? (Teknic73)
just pay someone extra money, u never know it might pass go to a place that only charges if you pass that way its like a free trial so if u dont pass u dont pay!
Old Dec 15, 2003 | 05:10 PM
trustbuddy's Avatar
i thought p&p wouldn't affect emissions.
Old Dec 15, 2003 | 06:40 PM
Lord Helmet's Avatar
p&p won't effect your emissions. I use to have a built ls engine with similar mods minus the skunk2 intake manifold, jdm ecu, and itr cams. I passed with no problems. the rule of thumb is to make the engine run lean as possible without detonation.
Old Dec 15, 2003 | 07:33 PM
obd2gsr's Avatar
Default Re: Grr, test only smog sentence in CA, wondering if p&p will pass? (sleeperciv)
Thanks, everybody, for your quick responses.
sleeperciv - Did you use Hondata to tune your vehicle? I have heard from numerous tuners, not going to mention names, that they can make most mildly modded engines pass emissions with Hondata.
Old Dec 15, 2003 | 07:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd2gsr &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, everybody, for your quick responses.
no I didn't use the hondata, it wasn't available when I had my DA. I just used the VAFC and leaned out the engine almost to the point of detonation.
Old Dec 15, 2003 | 08:08 PM
riceball777's Avatar
it might pass might not
just do an illegal smog
the only was ppl with moded cars pass smog now a days is by doing an illegal smog
Old Dec 16, 2003 | 12:18 AM
EMO-anthony's Avatar
Default Re: Grr, test only smog sentence in CA, wondering if p&p will pass? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">it might pass might not
the only was ppl with moded cars pass smog now a days is by doing an illegal smog</TD></TR></TABLE>
Old Dec 16, 2003 | 12:33 AM
thaiphob's Avatar
Nikon!!!
dont listen to ben. hes just mad b/c he blew his motor.
if its just a mild p&p is should pass smog fine. thats if you only have a p&p!!! if you have headwork i.e. cams, gears etc thats a different story.
you might want to consider a tune up before you goto the sniffer. check your plugs, wires, o2 sensor, cap n rotor, also fuel filter.
JManny
Apr 12, 2011 08:16 PM
bcpEG
Mar 23, 2009 10:52 PM
eegeesixtsu
Feb 7, 2005 06:36 PM
g's integ
May 19, 2002 08:15 PM
