JG Edelbrock IM users, FPR clearance issues. Need help
Old Dec 15, 2003 | 11:06 AM
PM-Performance's Avatar
Default JG Edelbrock IM users, FPR clearance issues. Need help
I installed my JG manifold the other day , got the fuel rail on and all . But i am seeing the return line port from the FPR is way too close to the Plenum . I cant get a line safely on it. Someone said to turn the FPR around upside down , but i have an adjustable FPR(AEM) and if its turned around i cant adjust it .
any ideas? SOmeone showed me a part from Jackson Racing becuase i guess they have the same prob, but thats like $45 or so by the time i get it with all the hardware, any other ideas?
Old Dec 15, 2003 | 11:12 AM
Opie's Avatar
Default Re: JG Edelbrock IM users, FPR clearance issues. Need help (itr206)
I'll ask a friend who has the same setup on his b18 an has no clearance issues
Do you have any pics to diagram the problem?
Old Dec 15, 2003 | 11:14 AM
Default Re: JG Edelbrock IM users, FPR clearance issues. Need help (opie112)
i do at home , i tried to post them yesterday , but my computer was acting stupid, ill post some later.
Old Dec 15, 2003 | 11:16 AM
RockstarJR's Avatar
pics
Old Dec 15, 2003 | 11:22 AM
Default Re: JG Edelbrock IM users, FPR clearance issues. Need help (ITRChris)
ill try to get some up , the nipple on the bottom of the FPR rub the plenum .
Old Dec 15, 2003 | 11:42 AM
RTW DC2R's Avatar
Ill post a pic later tonight to see if it helps you any.
Old Dec 15, 2003 | 02:49 PM
RTW DC2R's Avatar
Default Re: (RTW DC2)
here ya go pete, let me know if these dont help. its probably because im using the B&M and not the AEM FPR, the AEM had a kink in the hose...
***Also, note in this pic how I had to modify the throttle cable bracket on the IM. The cable didnt line up perfectly with the TB and it seemed to cause the TB to stick sometimes. I dremmeled the holes on the bracket larger so it was adjustable and seemed to give enough adjustment. A longer throttle cable('92 GSR possibly) might have worked as well.
Gratuitous dirty engine bay pic. had to drive her in the salt and slush today
Old Dec 15, 2003 | 06:20 PM
yea see the B&M is kinda bent at the end. the AEM isnt. idunno if i wanna mess with it and try to bend it.
So the bracket didnt work as is huh . damnit. these parts are too good to be true sometimes.
Old Dec 16, 2003 | 01:05 AM
TurboR1391's Avatar
Default Re: (itr206)
Itr206, I am glad you did your install before me with this manifold and the AEM fuel pressure regulator because I have the same setup just not installed and I was thinking everything would just bolt right up with no problems. Keep us posted on how you get it to work.
Old Dec 16, 2003 | 03:25 AM
Default Re: (TurboR1391)
i dunno if you can see in the pics, but i need something like this. this guy will sell me one for $15
Old Dec 16, 2003 | 04:53 AM
RTW DC2R's Avatar
I did have my AEM FPR and Fuel Rail installed and working with my JG IM...and it was installed straight up and down like normal. The hose wasnt perfect but it worked. Obviously in a turbo set up with lots of boost you wouldnt want that though.
Old Dec 16, 2003 | 04:55 AM
i wouldnt trust a pinched return line on any set up . that s what it looks like it would do if i leave it like so
Old Dec 16, 2003 | 11:27 AM
Marauder's Avatar
The JG Edelbrock manifold with aftermarket rail and FPR doesn't work too well. The best bet would be to use a Edelbrock fuel rail, they designed it to eliminate the interference fit that most aftermarket rails have, and its a true flow-thru design, since the FPR is at the opposite end of the inlet fitting.
Old Dec 16, 2003 | 11:29 AM
Default Re: (Marauder)
well i just bought the one off the pic of the Del sol from above for $15 cant beat, that, thanks.
Old Dec 16, 2003 | 03:50 PM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">well i just bought the one off the pic of the Del sol from above for $15 cant beat, that, thanks. </TD></TR></TABLE>
that works
Old Dec 16, 2003 | 04:11 PM
tegedrex's Avatar
Jackson racing also makes an FPR relocator as shown above, so you can rotate it.
Old Dec 16, 2003 | 04:42 PM
Default Re: (tegedrex)
yea but its like $50 said and done and shipped. i didnt want to spend alot
Old Dec 16, 2003 | 06:44 PM
Opie's Avatar
Glad it seems to have worked out
Keep us posted on any results.
Old Dec 16, 2003 | 06:55 PM
ludicrous's Avatar
hey ITR206, can you share the info of the guy that sold ya that adapter...thanks
Old Dec 17, 2003 | 07:29 AM
Default Re: JG Edelbrock IM users, FPR clearance issues. Need help (ludicrous)
i got it from Swags04, i dunno if he has anymore, but check with him , he said he had them custom machined.
slowcar_dc4
Jun 19, 2017 05:42 AM
Turboteg00
Mar 27, 2010 02:29 PM
Muckman
Aug 12, 2007 09:19 AM
Mr HYDE
Mar 29, 2007 09:58 PM
PM-Performance
Dec 14, 2003 11:05 AM
