Removing A/C - separate belts?
Old Dec 14, 2003 | 08:03 PM
mstewar's Avatar
Default Not going to have A/C in my car.. Does that change anything, belt-wise?
Are the A/C, powersteering, and alternator all on different belts?
I don't have my helms at the moment and I'm not putting the A/C back in my car.. I couldn't remember if they shared or not, and if I'd need a different belt than if I had A/C in it..
Thanks!
Old Dec 14, 2003 | 08:04 PM
thk's Avatar
thk
Members Only
Default Re: Not going to have A/C in my car.. Does that change anything, belt-wise? (mstewar)
All different belts.
Old Dec 14, 2003 | 09:03 PM
mstewar's Avatar
Default Re: Not going to have A/C in my car.. Does that change anything, belt-wise? (thk)
So no A/C = just no A/C belt.. got it!
Old Dec 14, 2003 | 10:52 PM
Bbasso's Avatar
NO A/C???
What ya nuts?
Old Dec 15, 2003 | 05:44 AM
mstewar's Avatar
Default Re: Not going to have A/C in my car.. Does that change anything, belt-wise? (Bbasso)
umm.. i'm not going to be just cruising around with this thing in the middle of summer..
Old Dec 15, 2003 | 05:47 AM
baonest1's Avatar
are you going all out and taking the lines, condensor, compressor and everything off??
if so, that frees up a good amount of room. extra luggage space
Old Dec 15, 2003 | 06:09 AM
mstewar's Avatar
Default Re: Not going to have A/C in my car.. Does that change anything, belt-wise? (baonest)
i left the evaporator in, but everything else is out..
luggage space? lol..
Old Dec 15, 2003 | 06:14 AM
Bbasso's Avatar
But that long trip to AZ...
You might be kinda hot
Old Dec 15, 2003 | 06:33 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">But that long trip to AZ...
You might be kinda hot </TD></TR></TABLE>
If we decide to go, the car will be trailered.. By May, I wouldn't want to drive that thing anywhere far anyhow.. Not exactly going to be street friendly..
Old Dec 15, 2003 | 06:37 AM
sackdz's Avatar
You can remove the evaporator section from the housing pretty easily. It weighs around 5 lbs. Just cover the hole in the housing with some tape and replace it.
Old Dec 15, 2003 | 06:42 AM
Bbasso's Avatar
OH.... really.......
Old Dec 15, 2003 | 08:11 AM
baonest1's Avatar
i have all of the under dash boxes in. i just opened up the black one wit hall that **** in there and tore it out and put the box back in. so now i still have air flow.
Old Dec 15, 2003 | 08:16 AM
Smitdog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
If we decide to go, the car will be trailered.. By May, I wouldn't want to drive that thing anywhere far anyhow.. Not exactly going to be street friendly..</TD></TR></TABLE>
I would have to agree with you here. The new Bumper would become to nicked up and those 19's might find a way to bend a little on that trip. And the noise level.... with that show system might get old.......
Old Dec 15, 2003 | 09:16 AM
Willard's Avatar
remove ps also?
I have a single rib crank pulley FS.
Old Dec 16, 2003 | 08:42 AM
mstewar's Avatar
Default Re: Not going to have A/C in my car.. Does that change anything, belt-wise? (Smitdog)
hardy har har.. 19's.. lol..
baonest, your heat/fan still works, right?
Willard, see PM..
Old Dec 16, 2003 | 04:21 PM
baonest1's Avatar
yah, my fans still work. i gotta look into the heat. im pretty sure i am getting engine heat, but its not real hot. the temp lever thing is stick at like half hot half cold.. so i need to play with that to see if i can get it all hot.
Old Dec 16, 2003 | 04:43 PM
mstewar's Avatar
ah.. so that could be just a problem with the controls, not the actual heat..
Old Dec 16, 2003 | 04:48 PM
baonest1's Avatar
^ yesir, that was what i was trying to say. hah
LukieLuc
May 31, 2007 07:13 PM
flatblack-h22
Aug 17, 2006 05:53 PM
BB6-213
Apr 9, 2004 07:14 PM
NoLipRacen
Mar 13, 2004 01:01 AM
wizzards581
Sep 15, 2003 07:31 PM
