Brake Lights DONT WORK!!! HELP!!
Old Dec 14, 2003 | 06:43 PM
Kisses_89_HB's Avatar
Default Brake Lights DONT WORK!!! HELP!!
Ok i was driving normal like any other day. Came to a red light stoped *note me and my uncle are driving together he's behiend me* light turned green pulled off normally next light my uncle signaling me to pull over. I pull over he tells me i have no brake lights we check fuses no fuses are blown what could be wrong with my brake lights?
Sorry for the long drawn out story i just like to tell how it happend some people like to be like maybe he bumped u in the rear or maybe ya blub is blown if the blub was blown i think still one of my lights would light up any ideas?
Old Dec 14, 2003 | 06:50 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: Brake Lights DONT WORK!!! HELP!! (Kisses_89_HB)
your horn and your brake lights are on the same circuit check all your wiring. it's grounding out somewere. if you have a cold air intake on your car it could have cut the wires running down to the horn thru that opening from your engine bay to your bumper. thats where mine was cut and grounding out.
does your seatbelt light flash when you hit the brakes? or when it's damp outside?
Old Dec 14, 2003 | 06:57 PM
Default Re: Brake Lights DONT WORK!!! HELP!! (LudeEFv2.0)
Nah my seatbelt light only comes on when i 1st start the car up
Old Dec 14, 2003 | 08:54 PM
Infinite Auto's Avatar
its a ground somewhere or a crazy set of brake lights that blow at once
Old Dec 15, 2003 | 04:43 AM
REDBARON's Avatar
Default Re: Brake Lights DONT WORK!!! HELP!! (B18TurboEF)
Have you checked the brake switch stopper pad? My brother had the same problem as you, and it was the little pad that makes the brake switch get pressed on the brake pedal. It's # 13 in this picture. After time, that thing clumbles, and allows the brake switch to go in the hole where the pad is suppposed to go. Check to see if that's your problem.
Old Dec 15, 2003 | 06:14 AM
Alan Wil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kisses_89_HB &raquo;</TD></TR><TR><TD CLASS="quote">Ok i was driving normal like any other day. Came to a red light stoped *note me and my uncle are driving together he's behiend me* light turned green pulled off normally next light my uncle signaling me to pull over. I pull over he tells me i have no brake lights we check fuses no fuses are blown what could be wrong with my brake lights?
Sorry for the long drawn out story i just like to tell how it happend some people like to be like maybe he bumped u in the rear or maybe ya blub is blown if the blub was blown i think still one of my lights would light up any ideas?</TD></TR></TABLE>
If the brake light switch checks good (See RedBaron's post) Check to see if your getting power and ground to the blubs themselves. May be easier to do that first.
Have you looked at the wiring digram(s) in the serivce manual?
Modified by Alan Wil at 9:33 AM 12/15/2003
Old Dec 15, 2003 | 06:19 AM
therealciviczc's Avatar
I would check the switch first, and let me highly recommend getting a Honda replacement switch if the switch is bad. My girlfriend's lights stopped working on her hatch. I drove straight to autozone and changed it out. That switch lasted a few months. I put another autozone one in (thought first might be a fluke) and it lasted a few weeks (the rod that pushes in would become very loose). Put a Honda one in and it lasted until we sold the car which was probably about 2 years.
Old Dec 15, 2003 | 06:21 AM
dilbert's Avatar
Default Re: Brake Lights DONT WORK!!! HELP!! (REDBARON)
I had my tail lights keep blowing fuses before but when I put a mulit-meter on the fuse it said it was still good. That was because the one metal tab on my fuse panel was not contacting the side of the fuse fully and would literally melt the plastic of the fuse! I ended up getting a new fuse panel. Good luck.
Old Dec 16, 2003 | 10:24 AM
LudeEFv2.4's Avatar
way to many posibilitys for brake lamp failure. i hate wiring
David Bromberg
Oct 2, 2012 09:41 AM
decode33
Honda CR-V & Element
Feb 25, 2011 10:49 PM
toolbox21
Mar 17, 2009 08:31 PM
AcuCrazy
Oct 28, 2008 11:27 AM
Draggin99Si
Aug 23, 2004 06:59 PM
