450cc's with a14b please tell me yes/no!
ok I keep asking for help ive got some giudence but mostly only links and people pointing me hte other way...I need to know if 450cc injectors and too big/small ugly whatever for a 14b turbo on a d16a6, probably around 5-6 psi of boost. I am looking for a good daily driving car so by that please tell me if they are ok.
450s are common to run with t25s and 14bs. do a quick search in the FI forums. it all depends on the management you run.
FYI, I'm planning on tossing a T25 on my a6, and I'm looking into getting 450s. more headspace than 390s.
yes they will work, but you'll have to get an safc to tune it slightly b/c without it the engine will prolly stall from too much fuel. I plan on putting a 14b into my hatch with 450's and i'm hoping it will work out well. you should check out http://www.homemadeturbo.com HIH!
ok so with an safc it will be a good running car right? I dont want a clicking knocking stalling car if you know what I mean...so hers my list.
14b
intercooler
450's
safc
anything else?
14b
intercooler
450's
safc
anything else?
When using the 450cc dsm cut and switch the fuel injector wires around(all 4 injectors)the honda clips plugs right into the 450cc injectors.I also ran a vafc hack.Get some tuning after that and it'll run perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicedREX »</TD></TR><TR><TD CLASS="quote">would an safc still be needed if I got smaller injectors? just wonderin</TD></TR></TABLE>
You always wanna have something to correct the fuel you'll be using/need to use. Just use the 450cc and the AFC. Also check for a fuel pump(DSM) they are cheap and will give you enough pressure.
Good luck. Happy boosting
450's afc up to 10-11psi. or you can run the Vortech FMU and afc on stock trim. clean and balance those injectors. they're used i persume....you don't won't an injector fail on you or get stuck open
