driving in snow?
Old Dec 14, 2003 | 05:31 PM
DrewQ1's Avatar
Default driving in snow?
whats a good gear to drive in the snow and so i also wont kill my clutch.
Old Dec 14, 2003 | 05:34 PM
Nick H's Avatar
New User
Default Re: driving in snow? (DrewQ1)
you can start in second if you so desire...if you have good tires, starting in first is fine...just keep the rpm's down to maintain control of the car better...
Old Dec 14, 2003 | 05:45 PM
DrewQ1's Avatar
Default Re: driving in snow? (Nick H)
starting in second wont hurt the tranny or clutch
Old Dec 14, 2003 | 05:53 PM
Nick H's Avatar
New User
shouldn't hurt the tranny, should be alright with the clutch as long as it isn't 3rd or anything
Old Dec 15, 2003 | 07:35 AM
KGAccord's Avatar
i start in 1st gear, it's all about modulating the gas and clutch to limit wheel spin. i also have dunlop graspic ds-1 studless ice tires.
Old Dec 15, 2003 | 08:27 AM
WongFeihung's Avatar
Default Re: driving in snow? (KGAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord &raquo;</TD></TR><TR><TD CLASS="quote">i start in 1st gear, it's all about modulating the gas and clutch to limit wheel spin. i also have dunlop graspic ds-1 studless ice tires.</TD></TR></TABLE>
ya, i start in first too, then shift to second at a low rpm range..usually depending on my judgment according to how bad the weather is...anyhoo, I agree with about modulating the gas and the clutch. The best way is always be cautious..relax and use your judgment.
Old Dec 15, 2003 | 08:52 AM
. C h e n l a's Avatar
Default Re: driving in snow? (WongFeihung)
i just floor it,..
j/k i usually just use first really slowly..
Old Dec 15, 2003 | 09:35 AM
.bagged's Avatar
Default Re: driving in snow? (NiNeFouRCorD)
just nut it and feather the e-brake....hehe.. No just go slow and give yourself plenty of stopping distace and you will be fine...Bend OR..7 inches last night..
Old Dec 15, 2003 | 10:13 AM
skabone's Avatar
Default Re: driving in snow? (bagged93accord)
as long as you keep your RPMs low and you don't gun it you should be fine.
Old Dec 15, 2003 | 01:23 PM
IAmCman's Avatar
Default Re: driving in snow? (skabone)
What's wrong with gunning it?
Old Dec 15, 2003 | 01:29 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewQ1 &raquo;</TD></TR><TR><TD CLASS="quote">whats a good gear to drive in the snow and so i also wont kill my clutch.</TD></TR></TABLE>
Could you explain how you would kill the clutch, while driving in the snow? It's not like you rev the engine up to 8000rpm and then release the clutch correct?
As if now, my car is horrible in the snow. Got LSD, with a fidanza flywheel and ACT XTSS, and Yokohama Parada Spec II (Summer Tires) While My tires are turned all the way to the right, my car continues to drive straight.
Old Dec 18, 2003 | 06:03 AM
White 99's Avatar
best thing to do in snow is drive in a gear higher than normal, ie: shift earlier than normal.....it keeps rpms/torque to a minimum and your tires are less likely to break loose.
Old Dec 18, 2003 | 07:05 AM
Phaulkyou's Avatar
I drive the exact same way in the Snow as i do in the dry. The only difference is that i keep a little more distance on cars, and i have my hand on the hand brake during most turns. other than that, shifting stays the same, speeds stay the same, etc.
Just dont think about it.
Old Dec 18, 2003 | 10:30 AM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: (Phaulkyou)
Clutch drops at 7K RPMs, that way you melt all the snow under the front tires, and away you go on your merry way
Five Liter EATER
Transmission & Drivetrain
May 21, 2009 05:36 PM
kelviiv
Sep 18, 2008 05:38 PM
yeegsr
14
May 17, 2007 05:25 AM
PrettyFastRide
13
Jul 13, 2006 06:30 AM
aznmc16
Jan 1, 2003 02:39 AM
