I FU>>>p, I messed up mu block is it fixible?
I was grinding the blocks with the dremel left side, where the compressors sits, it was hitting the block. But I took it to far and did a little hole(it went trough) on the block about 1mm less than that, I put some JB weld on it do you guys think it will hold? I think it should sice there is no real pressure on there need you guys opinions!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rondigs »</TD></TR><TR><TD CLASS="quote">If you can see a rod, JB weld isn't gonna cut it. </TD></TR></TABLE>
Never underestimate the powers of JB weld... but when you can get the job done right then do it right. I developed a pinsize hole in my radiator due to the fan rubbing a fin... a little bit of JB quick weld solved that problem. Coolant is one thing, but oil is another.
I bet the JB will hold too if it's on there good, there isn't any oil pressure if he see's the rod, it's just the crankcase. The only reason I can see the JB coming off, like someone stated is the block heating up and cooling down. But I bet the JB will hold, there's no pressure pushing against it.
Here is a pics of another block is right under the big bolt in the 4 cyl
