Turbo oil supply line where should it go?????
Old Dec 12, 2003 | 12:43 PM
Boostin Ex's Avatar
Default Turbo oil supply line where should it go?????
Ok i just got my oil supply and return line in today from Tony at importpalace the supply line come's off the back off the head behind the distributer where there is a allen head plug from the factory is this a safe palce to tap into the oil supply for my turbo? I dont know how to host any pics of it but if someone can ill send them pics if they can host them for me so that everyone can see.
Old Dec 12, 2003 | 01:25 PM
Flamenco-T's Avatar
Default Re: Turbo oil supply line where should it go????? (Boostin Ex)
I would not tap it into the head area, the oil pressure is not constant and and may increase a chance of oil starvation to the turbo.
All my customer's kit use the block by the oil pump as the source, therefore there will be a constant flows and pressure as well..
stan
Old Dec 12, 2003 | 01:34 PM
Boostin Ex's Avatar
Default Re: Turbo oil supply line where should it go????? (Flamenco-T)
Ok i just got off the phone with Tony at importpalace and i was misinformed the supply does come off the head but it come's directly from underneath the distributer he say's you remove one of the factory plugs and get the oil from there. I am open to suggestions because if you guys feel this is not safe then i will get something else. Thanks for some input Flamenco-T
Old Dec 12, 2003 | 01:49 PM
EG6owner-T's Avatar
ok what motor is this a b series or h? why not do where everyone else get their oil supply the oil pressure sensor?
Old Dec 12, 2003 | 01:54 PM
Boostin Ex's Avatar
Default Re: Turbo oil supply line where should it go????? (EG6owner)
Its a B series motor i didnt know that the oil line kit i ordered was different until it got here i was like WTF this want go to the back of the block so i called and asked Tony about it and he explained to me how this oil feed line worked.
Old Dec 12, 2003 | 01:58 PM
Flamenco-T's Avatar
Again, the head does not always have a constant oil pressure, the block does that's why the oil pressure sener are there.
There was a few discussions about this and many had concluded it.
stan
Old Dec 12, 2003 | 05:03 PM
the-anti-crack's Avatar
you dont want to take oil away form the head.
are you talking about the vtec oil pressure test area?
if i was you i would really consiter buying the kit from flamenco-T. its good quality, and fast delivery. one hell of a guy.
jdm91CrxSi
Jun 24, 2006 02:23 PM
killa_lude
Aug 21, 2004 11:44 AM
aznpreludeSH
Mar 19, 2004 03:54 PM
blufke
Nov 4, 2002 10:25 AM
lswithvtec
Nov 27, 2001 11:06 AM
