Head Gasket and Cam Timing
Old Sep 20, 2001 | 09:00 AM
Crazy DA's Avatar
New User
Default Head Gasket and Cam Timing
Does milling the head have the same effect as using a 2 piece head gasket in terms of cam timing?? I'm using a 2 piece headgasket with toda spec b's and wanted to know how to index my cams in order for them to be truly at 0! Thanks
Old Sep 21, 2001 | 06:22 AM
VTEC4GS's Avatar
Default Re: Head Gasket and Cam Timing (Crazy DA)
yes, its basically moving the cams closer to the crank and therefore retarding the cam timing. The ideal cam timing is not 0 especially for Toda cams, you need to degree them based ont he Toda spec sheet,
Greg
Old Sep 21, 2001 | 08:30 AM
Crazy DA's Avatar
New User
Default Re: Head Gasket and Cam Timing (vtec4gs)
vtec4gs: any idea where i can get this spec sheet besides the place where i purchased these cams from?? can i get it anywhere online???
[Modified by Crazy DA, 5:31 PM 9/21/2001]
Old Sep 21, 2001 | 01:36 PM
VTEC4GS's Avatar
any Toda distributor or Toda Racing themselves ... if you cant get it, let me know I have hardcopies, no soft copies so I'd need to fax it.
Greg
Old Sep 21, 2001 | 02:24 PM
Crazy DA's Avatar
New User
vtec4gs: thank you for your help, i will try to get em but if i cant i will give you a shout!! thanks again!!!
NewBorn_EG
Jan 16, 2018 11:12 AM
blykins
52
Nov 5, 2004 10:40 PM
CStyles45
Jul 26, 2002 12:06 AM
Xerzex
Oct 30, 2001 03:30 PM
Rodney
Sep 15, 2001 06:13 AM
