ITR sway bar on 90 CRX
Old Dec 12, 2003 | 09:57 AM
RRRex's Avatar
Default ITR sway bar on 90 CRX
Does it fit? Is it worth doing?
Old Dec 12, 2003 | 09:58 AM
RRRex's Avatar
Default Re: ITR sway bar on 90 CRX (RRRex)
That's the rear sway bar.
Old Dec 12, 2003 | 10:08 AM
filthyCREX's Avatar
curious myself..
Old Dec 12, 2003 | 10:36 AM
dilbert's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RRRex &raquo;</TD></TR><TR><TD CLASS="quote">That's the rear sway bar.</TD></TR></TABLE>
whats the rear sway bar??
I have heard it does fit but it screws with your camber a little. I looked into this before and I decided against it as the ITR sways are much larger than even upgraded sways and that would be REALLY stiff. Plus the fact that the larger the bar the more chance you have to rip the mounting brackets out! But those can be reinforced. I am going to buy the ST kit.
Old Dec 12, 2003 | 10:49 AM
Driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RRRex &raquo;</TD></TR><TR><TD CLASS="quote">Does it fit? Is it worth doing?</TD></TR></TABLE>
Yes and No.
ST sway bar. you can get the rear Suspension Technique bar for around $130.
And it's adjustable.
ITR bar isn't.
and it's not designed for your chassis.
the ONLY reasons you should EVER use a ITR bar is this:
1. you are a stunna and want to say you have an ITR bar on your car (this is the main reason people have ITR bars on their car)
2. you got the bar for free and rather spend money making it work.
3. you can't afford $130 for the ST bar.
4. all of the above.
Old Dec 12, 2003 | 10:54 AM
Mr Furball's Avatar
Default Re: ITR sway bar on 90 CRX (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">the ONLY reasons you should EVER use a ITR bar is this:
4. all of the above.</TD></TR></TABLE>
Soooooooo True
Old Dec 12, 2003 | 01:34 PM
stockcrix1616's Avatar
Yes and No.
ITR bar isn't.
always buy stuff that is designed for your car.
Old Dec 12, 2003 | 01:56 PM
Timmah!!'s Avatar
Yes and No.
ITR bar isn't.
I have to say man, you are the sway bar GOD!
WTB: ITR rear swaybar
Old Dec 12, 2003 | 03:13 PM
bryant's Avatar
5. You cant fit the ST bar becuase it hits your exhaust.
Old Dec 12, 2003 | 04:15 PM
89civicdx's Avatar
Yes and No.
ITR bar isn't.
I use an ITR bar...works great...drilled some holes in the lever arms, shazam its adjustable.
WoW I guess I'm a stunna or something
I guess I'll be a Super Stunna once I get my hands on one of these babies
http://www.colemanracing.com/s...d=657
hmmm , hollow tube, 1 1/4 " ...I think I'm going to jizz myself
But since its not for my chassis I guess I will be putting myself in stunna territory.
Old Dec 12, 2003 | 04:21 PM
89civicdx's Avatar
Default Re: ITR sway bar on 90 CRX (Bryant)
Ohh man I know who you are dude why are you even bother asking on here...just go to any touring car race at shannonville/mosport and look under some cars.
I thought you were a newb at first....I say go grab some tubing and build your own bar.
Did you fix your motor yet?
Old Dec 12, 2003 | 04:31 PM
Driven's Avatar
Default Re: ITR sway bar on 90 CRX (89civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote">I use an ITR bar...works great...drilled some holes in the lever arms, shazam its adjustable.
But since its not for my chassis I guess I will be putting myself in stunna territory.</TD></TR></TABLE>
you're canadian, so, that doesn't count for much
and about the hitting your exhaust...
I don't have that problem .shrugs. I know a lot of people don't.
Old Dec 12, 2003 | 04:34 PM
89civicdx's Avatar
ok no hard feelings my american friend
Yeah the st bar shouldn't hit the exhaust(I've had it)...if it does move your exhaust around or lower the bar...easy fix.
Old Dec 12, 2003 | 08:21 PM
RRRex's Avatar
Yeah, I'm Canadian and no I haven't found a new motor yet. C5s aren't that easy to find. There's an importer in 'Ssauga that's has a shipment coming in in Jan. and has earmarked one for me. Also thinking about going whole hog and buying a race motor. Not sure.
Everything else on the car is ITR might as well do the sway bars as well. But since it's a track car I don't want to rip apart the back end. Moose ripped apart his with an anti-sway bar that was a little thicker than an ITR. Don't want to do the same.
aemintgsr
Jan 19, 2008 05:09 PM
KLiK
Feb 11, 2007 07:34 AM
dat_flip
Suspension & Brakes
11
Jan 28, 2005 07:38 PM
HybridIntegra
20
Nov 16, 2004 07:38 PM
unknown2
Sep 2, 2004 06:29 PM
