H22A into EG/DC axel question
Old Dec 12, 2003 | 04:22 AM
ozzyman's Avatar
Default H22A into EG/DC axel question
I have an OBD1 JDM H22A with LSD in my 2001 Integra. One of the major problems Ive had that I wasnt able to fix was my 'binding' issues of my DSS Stage 1 axels. My car is lowered with H&R race (2.5) and Tokico blues. Rollin' on 14 inch steelies. Shitty suspension setup, I know.
The problem is that when I drive over a 'dip' in the road my axels will bind and make this vibration. When I say 'dip' I mean when I drove over it, it will make my whole car swoop down, but usually I wont scrape or anything. Its really hard to explain. I feel the vibration coming from both the driver and passenger side.
I'm not sure if my car is too low or if I need bigger wheels or what. Has anyone had this problem from DSS axels?? Should I contact Frank about the problem?? If no one on here knows then I think I will resolve to him, but I would like to try and figure out the problem before I do.
BTW, pictures of my car will be updated soon!
Old Dec 12, 2003 | 01:42 PM
This One's Avatar
Default Re: H22A into EG/DC axel question (ozzyman)
Im having similar problems right now.
Your axles are the wrong length one way or another. Maybe they are setup for a certian mount kit you do not have.
There is alot of threads on this with alot of diff variations of what you can do or to help you understand whats going on
Old Dec 12, 2003 | 06:17 PM
ozzyman's Avatar
Default Re: H22A into EG/DC axel question (tHIS oNE)
Would Frank send me new axels??? Bump for anyone else having this problem.
Old Dec 12, 2003 | 08:48 PM
This One's Avatar
Call him up and make sure you got the right axles for your mount set
I have place racing mounts, and the axle combos everyones using for the Hasport mounts wont work as im finding out this week....
Old Dec 13, 2003 | 03:22 AM
ozzyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tHIS oNE &raquo;</TD></TR><TR><TD CLASS="quote">Call him up and make sure you got the right axles for your mount set
I have place racing mounts, and the axle combos everyones using for the Hasport mounts wont work as im finding out this week.... </TD></TR></TABLE>
Will do, first thing on Monday.
Old Dec 13, 2003 | 04:54 PM
b16hybridsol's Avatar
i had to switch to an 89 teg axle on my passenger side
Old Dec 13, 2003 | 05:23 PM
Newman's Avatar
New User
LSD = wider diff = need a shorter axle on the passenger side. In most cases, you would use a 90-93 Integra with (preferably, but not needed) a Prelude inner joint. With the LSD diff, you need a shorter passenger side axle, thus use a 88-89 Integra axle w/Prelude inner joint (or by itself with a little modification to the snap ring so the axle doesn't pop out of the tranny). Here's some more axle combo info that I wrote up earlier this year: https://honda-tech.com/zerothread?id=434668
Old Dec 13, 2003 | 06:47 PM
ozzyman's Avatar
Default Re: H22A into EG/DC axel question (Newman)
Thanks Newman, great info!
Also thanks for the great deal on my HCP mounts.
KillinEm18
Aug 23, 2012 06:52 AM
cpforyou
Jun 12, 2004 03:45 PM
ty_racer
Apr 1, 2004 10:45 AM
SpeedingHatch
Jul 15, 2003 05:25 PM
