LOVEFAB SST + HKS WG pix needed!!!
Like the topic says... anyone have a picture of a lovefab sst manifold with a HKS wastegate on it?? i'm planning on getting a lovefab sst manifold with the HKS standard WG and wanted to see how it would look with it and do anyone know if cody makes the manifolds so it will work for the hks wastegate??
I'm currently running a drag3 manifold and plan on upgrading to a lovefab sst, anyone know if i have to redo my down pipe and intercooler piping for this upgrade?? Thanks in advance
you will have to redo a few things, but if you are confident in turbology, youll be done in a couple hours.
I can make them w/an HKS WG no problem(I dont have any now, but I will soon).
And from what Ive seen, the HKS WGs use a different bolt pattern, or at least the "Standard", which is a 40mm hole, and uses 4 bolts in a rectangular pattern.
PM me for info, or go to my website, http://www.lovefab.com
